diyAudio Sponsor
Old 1st August 2009, 03:48 PM   #1
Default Richardson 5ar4
I was poking around ebay after my Sylvania 5ar4 didn't survive the move. Everything else was ok, but I guess this tube was getting old. Or, it could be that the Sylvania was running in my preamp and I moved it to my Simple SE after the move. Anyhow, it instantly self-destructed in a shower of sparks.
I found these Richardson 5ar4s, does anyone recognize them?
http://cgi.ebay.com/RICHARDSON-5AR4-...#ht_500wt_1182
Old 1st August 2009, 07:41 PM   #2
It says it could be a relabeled Bendix, which was a good brand. It also appears to be in a JAN box, which also implies some integrity. I would never drop $38 for a rectifier though.
Old 1st August 2009, 07:55 PM   #3
Cobra2 is offline Cobra2  Norway
DIY !
Cobra2's Avatar
Send a message via Skype™ to Cobra2
Why advertise "Richardson", is not National more well-known?
Arne K
Ars longa, vita brevis
Old 1st August 2009, 07:56 PM   #4
HollowState's Avatar
The tall miconal base and the third mica at the top if the structure does look very Bendix. It could be their version of the 6087 which was a GE 5 star rugged version of the 5Y3. Still, it looks like a nice tube. But leave it to shyster Richardson to re-label as they please.
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University
Old 1st August 2009, 11:16 PM   #5
I also found this looking around the web...
I have a National 5AR4 that is actually a 6106. The 6106 is a very nice tube actually, but is an indirectly heated 5Y3, and originally a Bendix part. It is rated much less than a 5AR4 however
here:
http://www.harpamps.com/micKtubes/GZ34-Varieties.html
As far as price, I've had a couple Sovteks that didn't last and a JJ that shorted about 10 seconds after the preamp was turned off, which blew a couple fuses and a couple ps resistors before I realized where the problem was. I'd pay a few times what a JJ costs to get a reliable, long lasting 5ar4. I don't think I'll take the chance that the "Richardson" is actually a 5ar4, though it could work ok in the preamp, but maybe not the Simple SE....
Old 2nd August 2009, 01:33 AM   #6
chrish is offline chrish  Australia
chrish's Avatar
I have had a failure of a JJ GZ34 that coincided with failure of the solid state rectifiers in my Simple SE. This was while I had a standby switch in the circuit. After removing the standby switch and the solid state rectifiers I have been using a Sovtek 5AR4 with no problems for over a year. I have also tried the soviet 5U3C (5U4G) with success. It does help to lower B+ a little if you need it, however it is directly heated and does not give the delayed power up of the 5AR4. They can still be found relatively cheap on ebay (but not as cheap as they used to be...).
Chris
Old 2nd August 2009, 12:19 PM   #7
hey-Hey!!!,
They're 6106's. IDH 5Y3. I got a set of 5 a while back, thinking I'd got a good deal on GZ34's. The seller took them back and then I found out about the Bendix tube....should have kept them; I got the sleeve for $27.
cheers,
Douglas
the Tnuctipun will return
Old 2nd August 2009, 04:07 PM   #8
Will diode in series with 5AR4 plate as discussed here solve this problem?
Old 2nd August 2009, 04:30 PM   #9
I've heard this before, and planned on doing this and possibly inrush current limiting as well. But after a year and a half of running my Simple SE every day... it even sees duty for tv/video amplification as well... I haven't had any issues. The Sylvania is the first problem I've had with the amp, and I suspect that was due to moving. I also make sure I let the amp cool for a while before turning it on again.
However, I have been using a Mullard 5ar4 with the amp, I don't trust any of the current production tubes although I'm using one now that the Sylvania died.
Old 3rd August 2009, 06:34 AM   #10
chrish's Avatar
Inrush current limiter is really easy to implement on this design, just solder one leg of the ICL to centre tap of the secondary and place the other lef of the ICL in to the screw terminal on the board. The diode trick would be more difficult, as the socket is soldered to the PCB.
I think it is worth trying the ICL before spending big on rare old rectifiers. Like I said, Sovtek working fine for me with this for over a year now.
Chris
bad 5ar4? sturmj Tubes / Valves 2 11th February 2009 07:09 PM
Got 5AR4 For Sale? john65b Swap Meet 0 3rd April 2008 07:59 PM
5AR4 heaters audio_moksha Tubes / Valves 3 22nd February 2008 05:43 AM
6v 5AR4? pftrvlr Tubes / Valves 7 9th February 2008 01:32 AM
Greetings from Richardson TX USA SteveGoTex Introductions 8 28th June 2004 05:20 PM
Page generated in 0.11099 seconds (79.20% PHP - 20.80% MySQL) with 10 queries
