| diyAudio Sponsor | ||
I have great difficulty finding power trannies here in this country.... I have one builder but does them in his spare time.
Now I can buy a voltage converter 220-110V for very little. 200W 220V-110V If I use this in a voltage doubler circuit I could get 260 Volts at 900mA I believe. 200/110=1.8 Amps 1.8/2 = 900mA. (loads of power) This could be an option no? |
#2 |
Tranny means something slightly different over here
If the voltage converter you are referring to is one of those cheap ones that has vents and seems light: forget it, there's no transformer inside; won't work. If you mean one that is transformer based, yes it could work, but I wouldn't count on either 260V or 900mA, both seem optimistic. Remember a voltage doubler has increased ripple and you will need to do something about this. Your best option is to look for a 1:1 isolation transformer.
Aerodynamics are for people who can't build engines. Enzo Ferrari |
#3 | |
I'm working on a project now and I'm running a small transformers salvaged from a power cube "wall wort" backwards, The transformar was designed for 120V-->9V but I put 12VAC into the "secondary" and get about 200V out, enough to run a preamp tube. I have a 120V-->48V CT transformer from a wheelchair battery charger. If I put 120V in the the secondary I expect to get 300V and about 2 amps. Look for things like these and remember you can two or more in combination. The cost is that you end up with a physically large, heavy and ugly looking power supply with loads "loss". but overall very low cost/watt ratio. |
#4 | |
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University |
#5 | ||
How do these work if they don't have a step down transformer? Quote:
#6 | |
#7 | |
Doesn't sound pleasant. So these would have a disastrous effect on a psu for a small load of 40mA or could they be used if enough filtering is added? I remember reading that someone used a laptop transformer with good success for the heaters. |
#8 | |
#9 | |
I had no idea the equipment I use everyday, eg laptop, had no isolation. That's a pity these cheap step downs are no good then. I got my hopes up before. |
#10 | |
| Tranny capability question... | 69CamaroSS396 | Power Supplies | 0 | 9th May 2009 05:00 PM |
| Another Tranny Question | bcrescen | Chip Amps | 7 | 26th September 2006 04:42 AM |
| Tranny question | keps | Chip Amps | 8 | 23rd September 2006 11:56 PM |
| Newnewbie Ouput Tranny question | zhoel | Tubes / Valves | 1 | 9th June 2005 04:42 AM |
| Quicksilver Tranny Question | wheezer | Tubes / Valves | 4 | 14th January 2003 01:29 AM |
| Page generated in 0.10939 seconds (81.06% PHP - 18.94% MySQL) with 10 queries |
