diyAudio Sponsor
Old 30th July 2009, 12:46 AM   #1
Default Power supply resistors power ratings
After looking at some RCRC networks, I wonder how the resistors used don't burn up. For example :
http://diyaudioprojects.com/Tubes/KT...Pull-Tube-Amp/
Scroll down and look at the PS resistor , a 100 ohm 5W unit.
How is this NOT burning to a crisp ? It is providing ALL the power for a pair of Class A KT88's ! Thats gotta be close to 50W combined on the plates .
Can someone enlighten me , PLEASE ?
As long as we're looking at this schematic, what is the benefit of loading the V2 tubes' screen with a resistor rather than directly tying it to ground as per the Melvin Lebowitz original design ?
Thank you................................Blake
Keep it simple
My Page Of SV and DIY Stereo Links
Old 30th July 2009, 12:56 AM   #2
leadbelly's Avatar
P=I^2 * R
For 100 mA, R=100, P=1W
For 200 mA, R=100, P=4W
The screen of V2 is not tied to ground, the grid is. The tube is drawn upside down.
Aerodynamics are for people who can't build engines. Enzo Ferrari
Old 30th July 2009, 01:04 AM   #3
"The screen of V2 is not tied to ground, the grid is."
My fault. Any idea why he used a resistor inline there ?
"P=I^2 * R
For 200 mA, R=100, P=4W"
Never saw that formula before.
Sweet shortcut !
Thanks...................Blake
Keep it simple
Old 30th July 2009, 01:57 AM   #4
leadbelly's Avatar
The design uses grid stopper resistors, while the one in the original article does not.
Old 30th July 2009, 10:55 AM   #5
Default grid stopper resistors
"The design uses grid stopper resistors, while the one in the original article does not. "
Yeah, I noticed that it is different than the original. I was wondering WHY he did it.
I thought a grid stopper went from the grid to ground , not in series with the grid.
Keep it simple
Old 30th July 2009, 09:46 PM   #6
chrish is offline chrish  Australia
chrish's Avatar
"P=I^2 * R
Sweet shortcut !
Yeah, it is that esoteric, rarely used, difficult to find thing called Ohm's Law
Old 30th July 2009, 10:48 PM   #7
Nobody likes a smarta** .
P=I^2 *R is NOT Ohms Law. It's not even Thevenin's Power Law.
Ohms law is V/I=R or I * R = V or V/R=I .
Amps squared , multiplied by Resistance equals Power is not taught in ANY school or books that I know of.
How did you come to know it ?
Any takers on the Grid Stopper question? A series resistance inline with the grid constitutes a grid stopper ? As I already said, I thought a parallel resistance from the grid to ground was considered a grid stopper. Can anyone clarify ?
Keep it simple
Old 30th July 2009, 11:07 PM   #8
Gordy is offline Gordy  United Kingdom
A series resistance in line with the grid forms a low pass (i.e. high cut) filter with the internal capacitance of the tube, and hence helps 'stop' it oscillating at high frequency.
Going back to the resistor / power question; remember that it is the power dissipated in the component / device that is to be considered and it is not going to be the same as that dissipated in the target load.
Power = Current x Voltage
Power = Voltage(squared) / Resistance
Power = Current(squared) x Resistance
The amount of power a component can take varies with ambient temperature (and sometimes with physical orientation).
Always choose a component that can handle higher power than the calculated figure. For example if you calculate a dissipation of 0.8W in a resistor it would be wise to choose a 2W resistor.
Old 30th July 2009, 11:11 PM   #9
Yes, used to stop oscillations. Hence the name stopper.
that is just a grid resistor, sometimes called a grid-leak resistor ( although I believe that term is not really applicable unless it is being used to provide bias, I may be nitpicking. )
used to drain away charge from the grid.
You can't be serious. I can't think of any elementary book that doesn't give it, and any advanced book doesn't have to.
It is simple algebra. If power is voltage times current, and if voltage is current times resistance, then power must be current times current times resistance, current squared times resistance
P = I * V
V = I * R
P = I * I * R
Robert McLean
Old 30th July 2009, 11:53 PM   #10
Thanks for the info. I had "Basic Electricity" (a 1 hour a day course) and "Electronics" ( a 2 hour a day course) in high school , and the variants of the power law using the square of voltage or current were never taught.
I never thought my teacher really knew what he was doing.
That was some time ago, about 15 years, but seriously this is the first time I have seen it used this way.
Thank you.
Here's a schematic of my current setup. Do I need stoppers or "leak" resistors ?
I plan on using CCS later.
http://img353.imageshack.us/img353/1...rrentsetup.png
.......................................Blake
Keep it simple
Choke input power supply, capacitor ratings 00940 Tubes / Valves 14 7th July 2009 05:52 PM
power supply resistors popping everytime i change them Clipped Car Audio 10 22nd April 2005 04:20 PM
Resistors in power supply icebear Tubes / Valves 19 8th December 2004 09:46 PM
power ratings of resistors alecwek Parts 17 4th August 2004 09:54 PM
Power supply transformer ratings deskmate88 Chip Amps 4 29th January 2004 05:29 AM
Page generated in 0.11260 seconds (82.67% PHP - 17.33% MySQL) with 10 queries
