diyAudio Sponsor
Old 28th July 2009, 08:27 PM   #1
Question How Set up Aria Mini 6P14?
i have this tube amp from two year.
i made a little upgrades: tube changed, paper oil capacitors, etc...
Now i have a problem, how can i set up step by step the 4 trimmer on pcb side?
i have oscilloscope, the classic 1khz software generator and multimeter.
Please help me
ps: i'm sorry for my poor english... i was the teacher nightmare...
Old 28th July 2009, 10:08 PM   #2
Default i forgot schematic
i forgot schematic...
Old 29th July 2009, 12:12 AM   #3
Gordy is offline Gordy  United Kingdom
I will try to help. I am not experienced with Push-pull, but let's have a go...
1. The trimmer pot located between pin 7 (of the 6N3) and ground: this seems to adjust the positive / negative symmetry of the output.
So, locate the trimmer of one channel, place a load on the output of the amp, feed in a test signal (example 1000 Hz sine wave at 0.250 Volts) at the input (of that channel), monitor the output of the amp using the oscilloscope, adjust this trimmer for + / - symmetry of the output either side of zero.
Repeat on the other channel.
2. The trimmer pot at the input: this sets the overall level of the channel.
So, locate the trimmer, place a load on the output of the amp, feed in a test signal to the input of the Left channel. Record the output signal level. Feed in a test signal to the input of the Right channel. Adjust the trimmer so that the Right channel has the same level as the recorded level of the Left channel.
I hope someone with more experience of Push-pull amps can confirm this. : )
Aria 6P14 makeover. audio1st Tubes / Valves 7 12th April 2007 03:24 PM
Assembling Aria Crossover, some help needed pjpoes Multi-Way 4 11th January 2007 01:21 AM
CAL Aria (original CD mech) tubenut Digital Source 10 29th April 2006 12:36 PM
Best crossover for Vifa and Aria 2? Layberinthius Multi-Way 2 1st April 2004 08:02 AM
ARIA 7 Focal Kit jleaman Multi-Way 0 27th May 2002 01:36 AM
Page generated in 0.07242 seconds (74.42% PHP - 25.58% MySQL) with 11 queries
