diyAudio Sponsor
Old 28th July 2009, 04:23 AM   #1
Default Bench Phono Pre Layout
I have a bunch of questions regarding layout.
First off, I'm building the pre using salas's shunt reg for the HV supply and 317s for the heaters.
Is it important that the power supply be housed in a separate box.
Are there drawbacks to doing it that way?
Does anyone have layout pics (I saw some of Sheldon's pics but it was hard to tell what exactly was going on there in the preamp and his PSU is different).
I was thinking I'd probably do this mostly point to point with a little help from some terminal strips. Then I can lay my heaters flat on the bottom of the chassis.
Any advice welcome, specific or general. Once I get a rough idea of what I want I'll work up some drawings and post 'em.
Ben
Eagle vs. Sprint-Layout for PCB design/layout hollowman Parts 9 9th July 2011 04:34 AM
Bench testing a SA/4e arnyk@comcast.n Pass Labs 1 6th January 2010 07:43 PM
Bench PSU sorenj07 Tubes / Valves 5 19th February 2007 10:53 PM
Recommendations on Ono phono stage PCBs or layout files luvdunhill Pass Labs 2 17th February 2007 04:23 AM
Regulated bench PSU UrSv Parts 84 24th September 2003 11:53 AM
Page generated in 0.06077 seconds (66.40% PHP - 33.60% MySQL) with 10 queries
