| diyAudio Sponsor | ||
Has anyone experience on how to install and adjust the driver tubes on my Audio Research Vt100 MkI. I dont find the junction between R7,8 and R11,12. The instructions and schematic seems to belong to a MkII. Shouldnt the MkI and II be identical in this regard.
Thanks, Kenneth |
#2 |
Unfortunately, not necessarily. You might try contacting ARC directly, and their site archive might even have the schematics for the VT-100. I long ago quit servicing ARC gear so I can't help you further.
www.kta-hifi.net |
#3 |
I think you will find the VT-100 schematic below.
http://www.arcdb.ws/VT100/VT100.html
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University |
#4 |
The schematic listed on arcdb is for a VT100 MKII which differs in some ways from the MKI although I do not know the specifics.
Contacting ARC for a service manual and schematics is probably the best bet.
www.kta-hifi.net |
#5 | |
I do know that at some point in time, AR stopped putting componet values on their diagrams in the instruction manuals and only referenced parts as R1 and C2 etc. Because values are given I would suspect this to be an older schematic. Just wondering. Can you shed some light?
#6 |
True, and it appears erroneously to me perhaps that rev 11 is rev II in adobe 8 linux version so I am not really sure. It could be the MKI schematic, but rev 11 seems odd for a design that lasted just two years before being replaced by the MKII version, and the MKII was made for a long time. The MKIII uses 6H30 so it is not hard to tell them apart..
www.kta-hifi.net |
#7 |
DIY !
VT100 MkII; what jfets are used?
I,m trying to repair one, and the fets are painted... Arne K
Ars longa, vita brevis |
| Audio research vs55/VT50/VT100 | jouch | Tubes / Valves | 2 | 7th June 2011 04:58 PM |
| Regulator adjustment | Prune | Parts | 6 | 16th June 2010 03:53 AM |
| Build a VT100? | petera77 | Tubes / Valves | 12 | 22nd February 2008 10:02 PM |
| Nak BX-125 azimuth adjustment? | TDWesty | Analogue Source | 8 | 9th February 2007 12:22 PM |
| Adjustment of CDM 4/19 ,any help please! | zygibajt | Digital Source | 0 | 20th November 2004 10:18 AM |
| Page generated in 0.09397 seconds (72.39% PHP - 27.61% MySQL) with 10 queries |
