| diyAudio Sponsor | ||
Friends
What is a "gridless control" tube ? I read in this article: " During that November, in an attempt to either replicate his work with the flame detector, or possibly to make his device different from Fleming's, de Forest sought a patent on a device that consisted of a filament, an anode and a control electrode of sorts (not a grid). Such a tube could not have provided de Forest with any useful gain. (However, years later, this principle of “gridless control” was successfully adopted by Heintz & Kaufman Ltd. and was the basis for their “Gammatron” tubes.) " What is this principle ? Thanks, Aldovan |
#2 |
Sounds like you're asking about a thyratron. A three element device (tube) used for control purposes.
http://en.wikipedia.org/wiki/Thyratron
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University |
#3 |
These could be cold cathode gas-filled diodes, that do not conduct at 'normal' operating voltages. A radiation source - such as gamma rays, or ultra violet light, ionises the gas, making the tube conductive.
These were used for instance as flame failure detectors in furnaces. Some had an extra 'holding' electrode to maintain the conduction state if the ionising radiation was removed.
Steerpike's Toybox |
#4 |
A gammatron is basically a tube with a cathode and 2 plates.
It was an attempt to get around the DeForest patent for triodes, which uses a grid between the cathode and plate. The gammatron has one plate beside the other. The main current goes from cathode to one plate, and changing the voltage on the other plate will draw away more or less of that main flow of current. There is an article on the web somewhere about using full wave rectifier tubes at reduced voltages to produce a gammatron effect. I have never tried it myself.
Robert McLean |
#5 |
Robert
Yes, Gammatrons !!! I use a gammatron 3C24 in audio and sound fine. See my amplifier: http://www.youtube.com/watch?v=rcVQkrff6pM But this gammatrons have grids and is possible the plate current control. But the grid voltage in my application is positive. Do you have this link for the gammatron effect ? Thanks, Aldovan |
| What makes an amplifier "bright", "warm", or "neutral"? | JohnS | Solid State | 51 | 13th December 2009 06:42 PM |
| "sensorless" soldering iron temperature control | star882 | Parts | 3 | 24th May 2009 08:44 AM |
| The "Leap-Frog" Method Of Switching Amplifier Control Loop Design | analogspiceman | Class D | 29 | 1st December 2006 03:21 PM |
| Is it possible to get "tube sound" with just a tube preamp and chipamp output? | Spasticteapot | Instruments and Amps | 43 | 15th May 2006 05:28 PM |
| "Start me up..." AlephX with relais control and powermanagement. | joho | Pass Labs | 26 | 22nd December 2005 02:47 PM |
| Page generated in 0.08162 seconds (71.55% PHP - 28.45% MySQL) with 10 queries |
