| diyAudio Sponsor | ||
Just about ready to finish the box. Not a metal case.
If I read Georges site correctly, when I'm hooking up the grounds, I also ground each speaker connector, either black or red. So am I connecting my speaker wire to the ground? Somehow this doesn't sound correct. Thanks, Paul |
#2 | |
Technically, it doesn't matter which side you ground, as it doesn't affect the phase or output. However, in an amp using feedback, which side is grounded does matter, as the phase of the feedback must be correct. Just for consistency's sake, it's best to always use the black connector for the negative pole, and ground it. Sheldon |
#3 |
Just to add to that, if you are using cathode feedback on the Simple SE, you may have to swap the secondary wires on the OPT. The feedback is supposed to be negative, so you actually need to connect the "positive" side of the secondary to the cathode to get negative feedback. You end up with the speaker + on the black wire of the secondary.
#4 |
Thanks for your help.
Someone else in a different thread also gave this advice about cathode feedback and switching the secondary outputs. If I follow Georges diagrams on wiring the switch, will it switch the outputs, or do I have to manually do it when I want to switch in or out cathode feedback? Thanks again, Paul |
#5 |
His diagrams make the swap, but read the accompanying text as well for caveats.
| 22 AWG silver plated solid copper wire for speaker wire? | G | Full Range | 21 | 15th February 2009 09:32 PM |
| Simple SE, how to wire CFB with outputs for different speaker impedances? | ciagon | Tubes / Valves | 1 | 28th August 2008 12:35 PM |
| What does the phono ground wire actually ground? | kirk57 | Analog Line Level | 7 | 30th May 2008 07:20 PM |
| ground wire very close to ac wires | jarthel | Parts | 4 | 21st April 2007 12:25 PM |
| No ground wire in my electrical outlets (USA).... | darkmoebius | Parts | 5 | 28th June 2005 10:30 PM |
| Page generated in 0.06969 seconds (79.06% PHP - 20.94% MySQL) with 10 queries |
