6C45 PP IT 845SE amp.
Old 21st June 2003, 09:57 AM   #21
James D. is offline James D.  United Kingdom
Nick,
It is possible to use neutralising capacitors with SE configuration - this is an RF technique so I'm not sure how succesful it will be at audio with SE configurstion.
A good explaination of the theory can be found in EIMAC 'Care and Feeding of Triodes' Neutralising Theory .
I found I need to go up in value from a value equal to the input capacitance but I start at about half the Cin and work up from there just in case.
A scope is some use but not all, ears are easily deceived so unless you have been taught how to do objective listening be wary (and if you have been taught then you know how much you have to be wary!), a spectrum analyser is the best tool for setting the value objectively...
hope this helps and good luck with your experimenting...
ciao
James
6C45 PP IT 845SE amp.Hide this!Advertise here!
6C45 211 Amp adharvey Tubes / Valves 5 22nd July 2011 07:20 PM
Low voltage 845SE with 300B driver Ziggy Tubes / Valves 6 18th February 2009 05:16 AM
845SE : comments on this circuit? Ziggy Tubes / Valves 10 12th February 2009 04:32 AM
6C45 in a phono amp? looks like this might be hot. MIKET Tubes / Valves 0 23rd March 2004 09:51 AM
6c45 bcherry Tubes / Valves 5 20th May 2002 06:36 AM
