diyAudio Sponsor
Old 25th July 2009, 02:33 AM   #1
Brit01 is offline Brit01  United Kingdom
Unhappy Help with my Transformer - vibrating
Hi guys,
Something strange is happening with my psu
Just stoppped working and blew the fuse on the primary.
I disconnected the psu, replaced the fuse, and placed a light bulb between the connections on the secondary.
Light bulb lit fine.
Now I replaced the rectifier, checked all connections, and then re-attached and powered up. The tranny shakes like a earthquake!! Immediately switched it off, checked everything and tried again. again the same vibration and no B+ voltage.
What's going on?
Old 25th July 2009, 02:40 AM   #2
Update:
I tried using my SS rectifier with the tranny and still it vibrates like crazy.
What's happening with the tranny? Has it died? Strange that it still illuminates the light bulb.
Old 25th July 2009, 12:10 PM   #3
whitelabrat's Avatar
Something is shorted, but I don't think it is the transformer. That's my first guess.
Old 25th July 2009, 12:14 PM   #4
chris661's Avatar
Same problem in the physics lab. The one we were using was very old, so it vibrated itself off the desk.
I'd try a new one.
Chris
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo
My setup: http://www.diyaudio.com/forums/multi...tang-band.html
Old 25th July 2009, 01:21 PM   #5
Shoog's Avatar
Excessive current draw from a short somewhere. If the transformer isn't giving off rank smelling smoke then its probably somewhere else.
Start by looking for blackened resistors - especially cathode resistors.
Shoog
Old 25th July 2009, 01:39 PM   #6
Had a good night sleep and checked everything in the morning. seems to be my tube power supply.
Tried a new SS power supply and everything works fine.
Very strange, checked everything visually on Bas's psu and everything looks undamaged. Have to do some probing.
Cheers
Old 25th July 2009, 02:12 PM   #7
Checking the circuitry:
D2 on Bas's psu is reading both ways
Blown diode here?
Old 25th July 2009, 06:29 PM   #8
richwalters's Avatar
A shorted diode creating half wave seems a possible cause.
On the otherhand; some years ago I came across a sim problem to find a 110V transformer wired for a 230V supply. Over voltage leading to core-saturation can also cause sim noises. Check primary wiring config.
richy
Old 25th July 2009, 07:16 PM   #9
Turned out to be one of the diodes! Swapped it and all works fine now
Old 26th July 2009, 04:30 AM   #10
Although you may have found the fault; there may be an underlying reason behind this: It may repeat.
Is surge current (input inrush) into cap input filter too high ?
Too high reverse peak volts for diode? (Vrrm ratings)
Mechanically busted.
An anti surge fuse used in primary ?
richy
Why is my amp vibrating? wwenze Chip Amps 4 13th May 2009 03:50 PM
Vibrating cutter...any available gmphadte Parts 10 7th December 2007 08:10 AM
ONKYO D-TK10 - "Vibrating" Speakers sdclc126 Multi-Way 0 16th August 2006 04:45 AM
vibrating trannies and hum? kmj Chip Amps 0 10th January 2006 11:03 PM
toroid Transformer as output Transformer for tube preamp? tone Tubes / Valves 15 2nd February 2003 04:36 AM
Page generated in 0.09688 seconds (79.13% PHP - 20.87% MySQL) with 10 queries
