Hi guys,
Something strange is happening with my psu
Just stoppped working and blew the fuse on the primary.
I disconnected the psu, replaced the fuse, and placed a light bulb between the connections on the secondary.
Light bulb lit fine.
Now I replaced the rectifier, checked all connections, and then re-attached and powered up. The tranny shakes like a earthquake!! Immediately switched it off, checked everything and tried again. again the same vibration and no B+ voltage.
What's going on?
What's going on?
Although you may have found the fault; there may be an underlying reason behind this: It may repeat.
Is surge current (input inrush) into cap input filter too high ?
Too high reverse peak volts for diode? (Vrrm ratings)
Mechanically busted.
An anti surge fuse used in primary ?
richy
richy
I've been experimenting with various designs of circuitry. First testing with psu2 but this is just approx I know.
I'm suspecting it was the 6080 I was testing. bought a load of new tubes last week and was testing a lot of them. Think I overloaded it with the 6080.
I need to get a new tranny built to run the heavy current 6080's for a future project.
- Tubes / Valves
- Help with my Transformer - vibrating
