| diyAudio Sponsor | ||
If I have 2 secondary windings at 12V 1amp and I wire them in parallel would I get 2 Amps at 12V?
Would this work for 6V heater filaments in series? for example 2 tubes in series with a 700mA draw each. Cheers |
#2 | |
Yes and yes.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
#3 |
The answer is yes. However, they must be wired in phase with each other. Out of phase and the tranny will draw tremendous current and burn out. In the case of two transformers, they should be identical.
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University |
#4 |
Thks guys.
Identical trannies yes. How would I know about the phase? Colour coding? Matching the colours? If the secondary windings have 2 wires coded black and 2 red. I would connect the black together and take this to eg. pin 4 >5 >pin 4> pin 5> then back to the 2 connected red wires of the 2 secondary windings. |
#5 | |
#6 | |
Great tip. Thks a lot. |
| Another quick transformer question | Hiwatt25 | Chip Amps | 6 | 8th February 2008 10:56 AM |
| Quick Transformer Question | krzanik | Tubes / Valves | 2 | 17th May 2007 09:15 PM |
| Quick Output Transformer Question | dsavitsk | Tubes / Valves | 5 | 20th April 2006 07:08 AM |
| Quick LM4780 Transformer Question | dfdye | Chip Amps | 4 | 16th December 2005 07:46 PM |
| quick transformer question | VictorG | Tubes / Valves | 2 | 9th January 2004 09:00 PM |
| Page generated in 0.07744 seconds (75.95% PHP - 24.05% MySQL) with 10 queries |
