diyAudio Sponsor
Old 22nd July 2009, 11:10 PM   #1
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Default Wavebourn Tower-III High-end hybrid amp
Enjoy. Since it is public domain already...
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Old 23rd July 2009, 12:03 PM   #2
ikoflexer's Avatar
Very nice, thank you for sharing Anatoliy.
Old 23rd July 2009, 03:14 PM   #3
Wavebourn's Avatar
You are welcome!
Triodes loaded on gyrators, source follower loaded on counter-modulated CCS. about 80W of idle power dissipation, 160W for stereo. Minimal load impedance is 8 Ohm, so 16 Ohm high efficiency speakers will be happy. Tower-II dissipated 1.5 KW for 2x200W output power, so this one is a summertime version.
Old 23rd July 2009, 03:18 PM   #4
ikoflexer's Avatar
Yes, I like the idea of gyrator load. Any first impressions sound wise?
Old 23rd July 2009, 03:38 PM   #5
Wavebourn's Avatar
This version exists on a paper only. The previous one I used during 2006 winter. The sound was the best I ever heard, though it worked also instead of a fireplace (1.5 KW dissipation). It caused subconscious reactions of listeners on sounds, I myself once was scared by a running water, other people were scared by a roaring lion. Father in law insisted that it was a real piano playing in our house. And so on.
That means, subconscious mind believed in reality of sounds.
Old 23rd July 2009, 04:09 PM   #6
ikoflexer's Avatar
That sounds impressive. Is that in the public domain as well? Wouldn't mind checking out the schematic if it is. This year we've got a very cold summer here, you know
Old 23rd July 2009, 05:48 PM   #7
Wavebourn's Avatar
No, Tower-II is not in public domain, but schematic is very similar. I used 8AL9 tube there, but loaded on CCS only instead of gyrators. It uses bipolar power, so DC stability was made by a feedback by DC with direct coupling between stages (through a voltage shift), also an output stage there is a bit more complex, with a degraded emitter follower in parallel with a source follower, and with one more source follower on top for bootstrapping (feed-forward, as well) to linearize in terms of dependence of transconductance and capacitances on drain-source voltage. However, it spends more power, but linearizes additionally without adding of higher order distortions.
Old 23rd July 2009, 06:57 PM   #8
Hi Anatoliy
I would .love to have one of those as a kit or ready built, how do I order?
I don’t worry about the heat, its cold here in the wintertime.
BTW: you should have some price and ordering info on your website.
Cheers
S
Old 23rd July 2009, 07:11 PM   #9
Wavebourn's Avatar
Originally posted by stinius
Hi Anatoliy
I can build one for you really cheap, in my barn, I'll calculate costs and email you.
Anatoliy
Old 23rd July 2009, 07:22 PM   #10
Anatoliy
Thanks A
BTW: Maybe I'll need more than 1.
Cheers
S
Best sounding headphone amp from Wavebourn to Kubeek :) Wavebourn Headphone Systems 131 2nd March 2010 02:45 PM
Paging Wavebourn - article on Russian caps... korneluk Tubes / Valves 1 14th June 2009 04:05 PM
Wavebourn Pyramid - VII driver stage Wavebourn Tubes / Valves 11 18th May 2009 10:31 PM
Wavebourn Alligator amplifier Wavebourn Tubes / Valves 25 8th May 2009 10:02 AM
Rock and Flame: Wavebourn Barracuda Wavebourn Tubes / Valves 13 24th July 2008 04:49 AM
Page generated in 0.11548 seconds (83.49% PHP - 16.51% MySQL) with 11 queries
