diyAudio Sponsor
Old 20th July 2009, 04:55 PM   #1
aldovan is offline aldovan  Brazil
Default Has anyone used The Guiguang 300B?
Friends
I see some Guiguang 300B tubes in ebay.
The look of this tube is fine.
Anyone have experience com this tube ? Sound fine ?
Thanks,
Aldovan
Old 16th December 2009, 07:58 PM   #2
bump - for any experiences with this tube - are they comparable to the shuguang? $50 cheaper and supposedly (as per ebay ad) sound better...
Old 17th December 2009, 05:00 AM   #3
kevinkr's Avatar
Curious, wonder why there was not a little (or a lot) more fanfare before they arrived on the market. Until I saw this post it had not registered that there might be a new manufacturer making 300Bs. (Maybe it is just another obscure branch of Shuguang, who knows...)
It is difficult to tell as I have not even seen recent Shuguang production, but from the lousy pictures on eBay there appear to be slight differences in plate structure. From what I can tell the Gui Guang appear well put together, but so did the Valve Arts 300Bs that failed very rapidly in my products about 9 yrs ago. (A lot will have changed in that time hopefully, but I have no recent experience)
Just some idle speculation on my part, I've been using JJ for quite a while now and not paying much attention to anything other than WE, KR and TJ..
www.kta-hifi.net
Old 17th December 2009, 10:28 AM   #4
работник
Rod Coleman's Avatar
hello Kevin,
I bet you're using the old sort of JJ300B too?
I love these, based on experience of 1998 manufacturing. Mine must have done thousands of hours - over ten years at my main listening station. Current driven filaments doesn't hurt lifetime! I looked at the getters recently and detected some 'early balding' signs. Uh-oh.
Have you heard any of the newer JJ productions? folks on here complained they were worse-built & worse-sounding a while ago.
Did KR ever fix their filament breakage problems, or is TJ the only item to compare to the old JJ?
Old 17th December 2009, 03:43 PM   #5
kevinkr's Avatar
Originally Posted by Rod Coleman View Post
hello Kevin,
Hi Rod,
I purchased my JJ 300B in 2001 sometime, but they may have been earlier production - I'm not really sure, but they do sound good and have been quite reliable.
www.kta-hifi.net
Old 17th December 2009, 03:50 PM   #6
i'll probably pick them up... $50/tube is pretty good - even if I have a set just to test new builds...
Old 17th December 2009, 04:13 PM   #7
kevinkr's Avatar
Yeah, hard to loose at that price, and who knows they might even be ok..
www.kta-hifi.net
Old 18th December 2009, 03:22 AM   #8
Hi all...
I see big price differences between sellers on Ebay for this tube. Anywhere from $102 per pair to over $300 for a pair. Are these for different types or are they all the same basic tube, but with different bases?
Thanks, Daniel
Old 18th December 2009, 07:38 PM   #9
Guiguang 300B tubes were made in Liuzhou city. After they bankrupted years ago, somebody bought the equipments and re-established a factory near Canton. Those on ebay are probably made in the new factory with the old equipments.
Old 22nd October 2010, 04:07 AM   #10
THD+N is offline THD+N  United States
I bought an amp in Guangzhou China recently while on a business trip with NGG (New Gui Guang) 300B's. They look to be assembled well, but as many have said... who knows.
I'll let you know how they work out. Recent Google searches are pulling up stupid money for these tubes. That doesn't mean they are good though.
About 10 years ago I bought some Sovtek 300B's and went through two pair in only a few months. the first pair, both filaments opened for now apparent reason. I checked my DC filament voltage and it was steady at 5VDC.
The online store I bought them from warrantied the tubes for me, and sent me a new pair. Before inserting the new pair of Sovtek 300B's, I doubled check the circuit, etc. All was ok. The new 300B's lasted about a month and the filaments opened up again.
I did not bother calling the online retailer again and through them in the garbage. I should have saved them just for bookshelf relics.
I modified the amp for 2A3's and have never had a problem. I don't think there was a problem with my filament circuit, but it was a strange incident with those Sovtek 300B's.
D-500, 700 II, 700B, (5) 400, (3) 400 II, (2) C-500, 4000 Preamp, Audio Precision System One (Dual Domain)
Best 300B SE OPT? bbaker6212 Tubes / Valves 29 6th September 2011 06:05 PM
FS: for 300B (JE Labs 300B SE) builders cartman Swap Meet 2 29th October 2008 01:13 PM
sub out in my 300b se? Help me please. fergs1 Tubes / Valves 1 4th December 2006 06:17 PM
300B like 845 rick57 Tubes / Valves 24 19th September 2005 10:33 PM
* 35 watt * 300B SE = super 300B + Class A2 rick57 Tubes / Valves 4 13th July 2005 04:18 PM
Page generated in 0.10923 seconds (81.87% PHP - 18.13% MySQL) with 10 queries
