diyAudio Sponsor
Old 17th July 2009, 09:18 PM   #1
athos56 is offline athos56  United States
athos56's Avatar
Default Quick Volume pot question
So if I use a 100k pot for the volume on my stereo buffer (both halves of one tube), would I use a 250k pot on a pair of buffers? (for pair stereo channels)
Old 18th July 2009, 06:15 AM   #2
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
No. 50k.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 18th July 2009, 07:31 AM   #3
athos56's Avatar
ahhh, thanks.
Old 18th July 2009, 01:54 PM   #4
Gordy is offline Gordy  United Kingdom
If you use 100K per channel now, then use 100K per channel when you add more channels. Or maybe I missed the point.
Old 18th July 2009, 02:03 PM   #5
boywonder's Avatar
I'm not sure that I understand the question either........If you are using 100K for one channel, wouldn't you use 100K x 2 (stereo pot) for two channels?
Old 18th July 2009, 03:39 PM   #6
athos56's Avatar
4 channels, 2 stereo pairs, 1 stereo pot, 2 channels per stack. So a single volume control for each channel, I couldn't find a 100k Alpha quad pot.
Old 18th July 2009, 10:15 PM   #7
4 gang pots difficult to source sometimes...
Attenuators available, but limited in steps...
www.dact.com/html/attenuators.html
This company is expensive, but does 46 volume steps, and custom up to 12 channels...
http://www.marchandelec.com/att.html
It seems as if this company has a 4 channel Alps RK-47 pot, but it is only 10K Ohms per channel...
http://electronics.dantimax.dk/Accessories/index.html
Or 4 channel (10K Ohm) TDK pots...
http://www.thel-audioworld.de/bauteile/regler/Potis.htm
Old 18th July 2009, 10:21 PM   #8
How about the goldpoint quad?
$249
http://www.goldpt.com/prices.html
Old 18th July 2009, 10:59 PM   #9
athos56's Avatar
Default All really nice
but I'm talking about an Alpha Co. pot that would be ~$5 bucks. I never really liked stepped attenuators. I know Alpha makes a quad pot, its just I can't find someone who sells it. So if I can't use a 100k quad (dual stereo) pot then I have to run the right channels off of one stack and the left channels off of the other stack. I figured that I would have to use a different value pot.
Quick question about CT and FWB athos56 Tubes / Valves 5 2nd May 2009 04:27 AM
Quick FET question spooney Car Audio 2 5th December 2007 05:05 AM
Quick quick question ! guitvinny Pass Labs 6 7th February 2007 04:20 PM
Quick LED question Nordic Parts 3 16th November 2005 01:04 PM
Quick fix for a staticky volume knob... The Paulinator Parts 8 4th April 2004 12:32 PM
Page generated in 0.08759 seconds (75.84% PHP - 24.16% MySQL) with 10 queries
