| diyAudio Sponsor | ||
The research continues before I plunge into building my first tube amp. I am looking into an attenuator to set it up as an integrated amp.
Is the Simple SE AMP compatible with the lightspeed attenuator shown in diyaudioprojects.com ? It is a highly praised attenuator (hopefully not overhyped). Has anyone tried a TVC attenuator with the simple SE - its flat frequency response should lead to a great balanced sound. Your input is appreciated in advance. Thanks Salsero |
#2 |
There's a whole thread in the Solid State forum on the Lightspeed. I'm building one into a tube amp of my own design (if I can ever stop working 12 hour days). It shouldn't present a problem.
Listen to the music through the stereo, not the stereo through the music. |
#3 |
I looked at the plans for the Lightspeed attenuator. It looks like a good idea, and is a fairly low impedance device (10K ohms). The input impedance of the Simple SE is much higher so it should not be a problem as long as your source can drive it. I am using a relay based attenuator with my Simple SE and it works fine. I have not tried a TVC.
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
#4 |
Wow...audio through an LDR. Never would have crossed my mind. Pretty clever.
#5 | |
LDR's kind of fell off the radar screen when better technology appeared. The originals used incandescent bulbs which resulted in a finite life time. The new ones use an LED which means that the power supply for the LED must be very clean or the hum and noise will directly modulate your audio signal. There is a whole counter culture revolving around the use of these things. A popular brand of light - LDR pair from the 1960's was Vactrol. That term now seems to be used in a generic manner to represent any form of LDR. Google Vactrol or "circuit bending".
#6 |
Yeah the term Vactrol is used for optoisolators in general and I've used them for digital stuff. Guess I'm just not that clued-in to professional audio. I was starting to have thoughts of digital control, but you make a valid point about introducing noise via the LED. Looks like matching is an issue too.
#7 | |
- Fred - |
| Simple, SIMPLE Digital volume control | -_nando-_ | Digital Source | 5 | 21st December 2006 01:20 PM |
| Simple Volume Attenuator IC Advice Needed | Ultima Thule | Parts | 25 | 13th October 2006 02:43 PM |
| Attenuator L-Pad switch to simple resistor problem | mudakas | Multi-Way | 3 | 13th September 2005 08:03 AM |
| Would like to build simple volume control or attenuator | Barry R | Multi-Way | 4 | 20th August 2005 12:28 PM |
| Simple answer required for a simple question... | rabbitz | Multi-Way | 4 | 31st August 2003 10:05 AM |
| Page generated in 0.08409 seconds (77.17% PHP - 22.83% MySQL) with 10 queries |
