| diyAudio Sponsor | ||
I have acquired a pair of THOM and SMITH Ltd. (Sydney Australia) Audio Transformers Part No MT. 03.540.2
According to the info plate on these trannies Primary is 7500 Ohm Impedance (510 Ohm DCR) Secondary #1 is 70,000 Ohm Impedance (2850 Ohms DCR) Secondary #2 is centre tapped 1100 Ohms Impedance (60 Ohms DCR). Physical size is 70 x 65 x 50 mm Anyone hazzard a guess as to what these trannies were originally used for? I'm intending to use them as phase splitters. Secondary #1 to diffamp driver grids and the centre tapped 2nd secondary for a bit of feedback in the diff driver cathodes (Centre tap to a current source). Does that sound feasible to you guys? Cheers, Ian |
#2 |
Sounds reasonable, but may be it is made to drive an output toob?
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#3 |
Thom & Smith made radios. There's a good chance your transformer was used in one. If you really want to know more about the transformer itself I'd hook up with the vintage radio collector world.
There are a number of vintage radio sites in Oz . Here's one. Look for a guy named Steve (Stephen) Savell. He has travelled all over the country documenting radio collections and if he can't help you put a finger on it he probably knows who can. |
#4 |
Those impedances almost appear to be 2-way radio transformers...
70,000 ohms would be the microphone.. 1100 ohms the headphones... The primary would be switched between the anode (receive) and grid (transmit). Just a guess from working with ancient AM TX's Cheers! |
| Sun Audio transformers | Toropkin | Tubes / Valves | 9 | 28th September 2008 11:37 AM |
| Audio Transformers 101 | dsavitsk | Tubes / Valves | 2 | 5th January 2008 11:20 AM |
| Old little audio transformers | miguel2 | Tubes / Valves | 1 | 13th June 2003 08:53 AM |
| crossover Audio transformers | macka | Multi-Way | 3 | 26th February 2003 12:30 AM |
| Page generated in 0.07437 seconds (71.26% PHP - 28.74% MySQL) with 10 queries |
