diyAudio Sponsor
Old 14th July 2009, 09:23 AM   #1
Calamaro's Avatar
Question Tube newbie problem
Just assembled a MD X10 clone kit.
Circuit is designed for 6DJ8/6922/ECC88 but I have two russian 6N1P. I know they require higher current: transformer in power supply is 12VAC, 45w.
When I switch on the buffer, led is ok, tubes became hot but I see no light from them. If I connect the buffer to my amp I can hear just a hum.
I really can't understand if I did something wrong in assembling parts (but it was very easy and clear), if tubes are wrong or they doesn't work at all.
Sorry for my dull question but please help
Old 14th July 2009, 10:22 AM   #2
SY's Avatar
A schematic or link to one would be helpful.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 14th July 2009, 12:28 PM   #3
pjp is offline pjp  India
pjp's Avatar
wired the heaters in series instead of parallel ?
Old 14th July 2009, 01:59 PM   #4
Calamaro's Avatar
Default Buffer Schematics
Schematics.
Old 14th July 2009, 02:01 PM   #5
Calamaro's Avatar
This was an unpopulated ready pcb.
Please see attached picture for populated pcb, with power supply, connectors and case.
Old 14th July 2009, 02:24 PM   #6
Calamaro's Avatar
Finished preamp. I like it so... I can't accept it doesn't work!
The good, heavy metal case comes from an old device: I made new front and back panels. Cover is white spray painted.
Tube covers are half tea filters
Old 14th July 2009, 02:40 PM   #7
SY's Avatar
Measure the heater voltages, the B+ and B- (carefully!) and the voltages at plates and cathodes. If both channels are nonfunctional, it's most likely a power supply issue.
Old 14th July 2009, 04:05 PM   #8
netbug is offline netbug  United States
I'm also very new to tube amps, so I may be missing something. But I don't see how a 12vac supply is going to get anywhere near the voltage to power a 6DJ8 (90volts) let alone a 6N1P (250volts).
Old 14th July 2009, 04:10 PM   #9
leadbelly's Avatar
1) The ECC88/6922's have been reported to work OK at lower voltages.
2) It probably uses voltage doubling to get a half-decent B+. My Scott Nixon TubeDAC uses the same technique.
Aerodynamics are for people who can't build engines. Enzo Ferrari
Old 14th July 2009, 04:43 PM   #10
ChrisA is offline ChrisA  United States
It looks like there are two voltage doublers on the power supply. It might be running the tubes between +24 and -24 for a 48V total. But I wonder why when there is AC mains available it is so easy to get all the power you'd need. OK, "Why" is not the question.
What's wrong it? My guess is you don't have the clean DC power you need. Check the outputs from both of the voltage doublers and see if there is ripple. You can pull out the tubes and check at the tube socket with an AC voltmeter or scope. A bad solder joint on a filter cap or a bad cap or a bad or poorly solders diode can cause this.
Page generated in 0.09429 seconds (77.23% PHP - 22.77% MySQL) with 11 queries
