diyAudio Sponsor
Old 14th July 2009, 02:14 AM   #1
Default Phase splitter types
I would like to know about phase splitters, which are quite linear, which not. I know there is the LTP, cathodyne type, etc..
The point is I want to build a guitar amp, and probably whithout cloning a popular one. Sure I'm gonna use sweep tubes as output.
Thanks!
Old 14th July 2009, 06:27 AM   #2
aardvarkash10's Avatar
Default books have been written...
...and wars fought in less time that it would take to answer your VERY broad question. Moreover, it would just repeat information already around. I suggest google...
Valvewizard covers the various species of splitters, as does Aitken Amps. this is good reading too
Yes, conservatism thrives on low intelligence and poor information. But the liberals in politics... continue to back off, yielding to the supremacy of the stupid. It's turkeys all the way down. - George Monbiot, guardian.co.uk, 6 Feb 2012
Old 14th July 2009, 06:38 AM   #3
Send a message via MSN to planet IX
Here is a good overview: http://www.bonavolta.ch/hobby/en/audio/split.htm
Boris
Old 14th July 2009, 06:49 AM   #4
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
For lead guitar if you want a classical overdrive you should go with what Fender did in last amps. IMHO.
One more option (it is one of my secrets) is to use a LTP - type class A output stage where the input tube is connected as triode, an opposite tube is connected as pentode with grounded grid. Very sweet sound, very musical overdrive. Try it. No need for an additional phase splitter.
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Old 14th July 2009, 07:59 AM   #5
Yvesm is offline Yvesm  France
Yvesm's Avatar
Looks like a perfect CCS feeding the other primary half
A better way to use an OPT than inserting an air gap ! for sure !
For "true" PI, pentodes LTP are seldomly used in audio although they give vy good results and sometimes void the use of an additional stage gain.
Use medium current/hi Gm types like 6BX6, 6EJ7 with starved g2 ... one of my secrets
Yves.
Old 14th July 2009, 08:08 AM   #6
Wavebourn's Avatar
You secret is very similar to mine (I drive GU-50 with parallel feedback by 220K from plates):
http://wavebourn.com/forum/download.php?id=119&f=7
Old 14th July 2009, 09:00 AM   #7
Yvesm's Avatar
Great !
DC stabilized too
Does R6 really need to be so hi ? DC shift ... I guess ? But eats 6dB !
After all, you seem to have plenty of gain to vaste . . .
Old 14th July 2009, 10:51 AM   #8
Ty_Bower's Avatar
Default Re: Phase splitter types
Originally posted by slideman82
I would like to know about phase splitters...
The point is I want to build a guitar amp...
There's a lot of helpful info here, in a format which I found easy to understand.
http://www.freewebs.com/valvewizard/index.html
Old 14th July 2009, 05:42 PM   #9
Wavebourn's Avatar
Exactly!
I would definitely shunt C6 if needed more OL gain.
Old 14th July 2009, 05:45 PM   #10
m6tt is offline m6tt  United States
If you are short on gain, use a cathodyne with directly coupled voltage amp, this uses one tube and provides good drive for fairly sensitive output tubes (EL84 etc.)
If you are short on drive or max voltage swing, use a LTP/Schmidt with low-Rp triodes with high current, this uses one tube but provides less gain than option 1. This is better for big tubes like 6L6, KT88...
you may still want additional grid drivers, cathode followers or mosfets after the PI if you have the space/power supply for these, they will help prevent blocking distortion.
Also, balance in guitar amps is not always that important, since you probably want a mix of odd and even harmonics. Otherwise the sound will be a bit sterile for anything but Jazz/Classical guitar.
Is this a phase splitter? tom-vdl Solid State 9 15th October 2009 08:21 PM
phase splitter with Tr ? sam8888ysl Tubes / Valves 9 22nd October 2008 11:28 AM
Help diagnosing phase-splitter pilli Tubes / Valves 13 5th July 2008 02:53 PM
Phase Splitter Name Gold_xyz Tubes / Valves 17 21st February 2008 09:48 AM
Phase splitter transformers kopite Tubes / Valves 2 15th July 2005 06:50 AM
Page generated in 0.11703 seconds (79.14% PHP - 20.86% MySQL) with 11 queries
