simple se troubleshooting - diyAudio
Old 13th July 2009, 04:12 AM   #1
Default simple se troubleshooting
So I just put together my simple SE and tested it for the first time. My choice of Tubes are the KT88's from Sovtek and the Power transformer is the Allied one. It sounds great when the music is really soft, but once I turn up the volume to a little over a whisper i get a lot of static and it sounds like a really bad radio or the gain is too high. My output transformers are the 125cse from edcor. I am using it in triode mode without cfb and they are runnig from the black and green lines which one the box says 8ohm/4ohm. 10000/5000ohm pri.
thanks
Old 13th July 2009, 12:33 PM   #2
Send a message via AIM to DigitalJunkie
125CSE? That's a Hammond part number,not Edcor.
http://www.hammondmfg.com/jpeg/125CSE_B.jpg
I assume you mean the speakers are connected to the Black and Green wires. http://www.hammondmfg.com/125SEsch.gif
Old 13th July 2009, 02:04 PM   #3
yes and yes
my bad for trying to build these at 3am ><. Sound wise its okay, I just have a slight hum and blew a fuse. I'm following up on this in my build thread. found it again.
mods please close this thread
thanks
Further Troubleshooting Simple SE Zap Tubes / Valves 6 29th August 2008 08:32 PM
Simple, SIMPLE Digital volume control -_nando-_ Digital Source 5 21st December 2006 01:20 PM
Troubleshooting Help wes-ninja250 Solid State 1 12th February 2005 07:22 AM
Simple answer required for a simple question... rabbitz Multi-Way 4 31st August 2003 10:05 AM
troubleshooting a P3A Patrat Solid State 12 19th December 2002 09:57 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
