Cary 845 schematics
Cary 845 schematics
Old 12th July 2009, 09:19 PM   #1
soulmerchant is offline soulmerchant  Switzerland
soulmerchant's Avatar
Default Cary 845 schematics
Dear all,
I am looking for the schematic for the Cary 845 (also known as Cary CAD 845 - not the SEI version though).
Thanks!
Old 13th July 2009, 12:17 PM   #2
Also, does anyone have some experience with this amplifier?
I have found something quite curious so far - There is a faint hum on the left channel. This may be due to a design flaw, or a modification by a previous owner (I am not yet sure - therefore the schematic would help a lot). The heater power transformer is separate in this amp, and is actually located directly below the left output tranny... I am about 99% sure that this causes the hum.
The hum is admittedly very minor and I am probably too much of a perfectionist... I took a LOT of care in transformer placement in my own SE amplifiers and they don't hum at all.
In any case, it would be nice to know if others have experience with this amp.
Old 13th July 2009, 12:39 PM   #3
korneluk is offline korneluk  United States
korneluk's Avatar
I have a pair of the bigger Cary 805B. I spoke to Dennis Had personally and he recommends using a cheater plug on the power cable to eliminate all hum.
If you'd like the service manual/schematics for the 805B, they are available oline (with a bit of searching), or ping me and I'll send you a copy.
-- jose k.
Old 13th July 2009, 04:43 PM   #4
I use a balanced input on this beast - a transformer volume control (TVC). So I am very hesitant to take away the only ground it sees by using a cheater plug.
I really think the problem is with the original layout. But there appears to be no other place to put the heater transformer...
Except maybe under the HT transformer. I will see if it could fit later this evening.
BTW - I contacted Cary and they told me that they can't send me the schematic for this amplifier because it is in Dennis Had's head!
edit: fix typo.
Old 19th July 2009, 11:51 AM   #5
vt4c is offline vt4c
I've a copy of Cary Audio's - CAD-805C service manual with schematic....Is this the version you're looking for?
Old 26th March 2011, 08:14 AM   #6
bigpappastevens is offline bigpappastevens  Canada
hi can you send me a schematic to the cary 805b amp
Old 29th March 2011, 03:17 PM   #7
commstech is offline commstech  Singapore
kwok, plse send me the schematic too.
Old 30th March 2011, 03:48 AM   #8
yes the cary 805c is ok
Old 25th April 2012, 12:54 PM   #9
khunpk is offline khunpk  Thailand
Please send me a copy of 805c schematicdiagram.
Old 26th April 2012, 02:25 PM   #10
sjs is offline sjs  United Kingdom
you could try this one Cary 805C service Manual
Cary 845 schematicsHide this!Advertise here!
Cary Cad-300b Se kmtang Tubes / Valves 25 26th November 2014 10:52 AM
Cary SLP-70 balance control... nelsondog Parts 0 27th January 2009 04:45 AM
Cary Audio V12 - Schematic - Needed Yukonsc Tubes / Valves 1 26th December 2006 06:03 PM
AE-3, PH-1, SE-811 (Cary) h_andree Swap Meet 0 6th August 2005 04:58 PM
Cary cd300 with HDCD pengxy Digital Source 0 19th November 2004 03:15 AM
