OPT Voltage spike protection with zeners
Old 12th July 2009, 05:00 PM   #1
bigwill is offline bigwill  United Kingdom
Question OPT Voltage spike protection with zeners
Simple premise, zeners facing into each other across the primary of an OPT that will clamp the voltage in the case of accidental load disconnection or amp misbehaviour to something slightly above the maximum anode swing of the amplifier is capable of. Zeners would probably consist of X amount of 200V zeners to make up various ballpark values, 400v, 600v etc
Is this worth doing? I don't think I've seen it implemented before. It sounds like a worthwhile addition to amplifiers considering high voltage 5W zeners are so cheap
Old 12th July 2009, 06:04 PM   #2
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
You may use some modern MOSFET with gate and source connected together. They work as Zeners on high voltages, and most of them have a diode that shunts an opposite polarity. However, if you connect gate to cathode of your output tube through an appropriate thermo regulated voltage divider you can get a "tube on steroids", like I do in my Barracuda amp.
Nothing in the universe is perfect. The ideal things are the ones that are most optimal. Optimization criteria, what matters. When I hear "No Compromise Design", I want to take a sledgehammer and test how impact-proof it is.
Old 13th July 2009, 01:28 AM   #3
ray_moth is offline ray_moth  Indonesia
diyAudio Moderator Emeritus
ray_moth's Avatar
I've read of it as a safeguard in pentodw amps, which are the ones normally associated with OPT primary overvoltage if the load is accidentally disconnected. I can't remember where I saw it though. A simpler safeguard would be to connect a resistor of about 1k permanently across the secondary, so it can never be completely unloaded.
Old 13th July 2009, 11:03 AM   #4
I have considered this, but I recall reading somewhere that a small load like that doesn't make much difference. If it would definitely work, I would be all for using that instead...
Old 13th July 2009, 11:06 PM   #5
tomchr is offline tomchr  Canada
tomchr's Avatar
There are some issues - primarily oscillations and RF emissions associated with those kinds of circuits. I suggest looking at some texts related to switchmode power supply design as the same issues are present there. On the primary side of the power transformer of a switchmode supply, you typically find all sorts of voltage limiters, snubbers, etc.
Whether adding such a circuit will prevent amp meltdown if the load is disconnected is another story. But it will limit the primary voltage...
~ Tom
Old 13th July 2009, 11:29 PM   #6
Wavebourn's Avatar
You may see diodes from plates to ground in ADA guitar amps.
Old 15th July 2009, 10:27 AM   #7
Merlinb is offline Merlinb  United Kingdom
Merlinb's Avatar
An alternative is to connect a gas-discharge surge arrestor across the primary. These can be bought with spark-over voltages of 600V and higher, ideal for the task, and they're practically indestructible.
Old 16th July 2009, 06:27 PM   #8
Hm, great idea! Wonder how hard these are to come by
Old 17th July 2009, 04:24 AM   #9
ChrisA is offline ChrisA  United States
Default Re: OPT Voltage spike protection with zeners
What is the capacitance of a non-conducting 5W zener? With the zener there you'd have a shunt to ground for some higher frequencies. But likely well above the audio range.
What about placing a fuse in series with the Zener? Then if it ever does conduct the fuse will blow quickly. Then you feed the B+ supply to the xformer through the fuse. When the Zener conducts the fuse blows and disconnects B+ supply and the amp shuts down. Or at least the OPT is no longer powered.
To answer the question about the gas discharge unit. They are very easy to find. They are used in communications antenna to shunt a lightening hit to ground. You can buy them from any place that sell radio gear for a few bucks each. But. I think they need some huge number of amps to trigger. They work when a spark jumps the gap and ionizes the gas which makes the gap more conductive. But they are made to handle 1000+ amps as in a direct lightening strike
Look here for more details
http://www.alphadeltacom.com/pdf/Tra...ech%20data.pdf
OPT Voltage spike protection with zenersHide this!Advertise here!
spike from SG3525 jegandren Power Supplies 7 13th September 2008 03:23 PM
no spike protection allowed tryonziess Chip Amps 6 13th May 2007 05:52 PM
Should I use high voltage value zeners or multiple lower voltage zeners in series? jarthel Parts 7 30th May 2006 04:56 PM
Speaker Spike bjackson Multi-Way 8 9th May 2005 01:12 AM
output device protection w/zeners pprasse Pass Labs 2 26th June 2001 06:05 AM
