| diyAudio Sponsor | ||
Hi Guys,
Is there a formula for finding the ripple out of a choke input filter? If there is can someone tell me it? Thanks a mill, Nick |
#2 |
Yes there is, but it is mathematically rigorous and requires several stages of computation, not to mention a little education in filter theory. I don't do it that way any more; I just plug my proposed filter into PSUD2, which has this math built into it, and let it tell me the answer.
http://www.duncanamps.com/psud2/index.html It's free. Thank you, Ben, Poinz AudioTropic |
#3 |
Ya I know unfortunately I'm on my mac and my pc is down stairs.
Also psud2 can't handle a power supply running 6500 vdc at 2.5 amps. You see my quandary LOL. And no it's not for an audio amp, college design project. Nick |
#4 |
It's not to hard to model power supplies in LTspice. Someone ran it on their Mac using a piece of software called Crossover?
http://www.evilmadscientist.com/article.php/crossover |
#5 |
The programs are called parallels and fusion. I'm familiar with them just haven't bought one yet.
Oh yes I see the one called crossover too. Still haven't spent the money yet LOL. Nick |
#6 |
OK, here's an oversimplified method: Assume you're starting with 100% ripple at 120 Hz. You have a voltage divider - choke reactance and capacitor reactance. So let's say you have 3 Henries (2.26K @ 120 Hz) into 16 uF (83 Ohms). That's 27:1 so you're down to about 3.3% p-p ripple.
But PSU designer has no problem with 6500V and 2.5A - and it says about 5% ripple. |
#7 |
I didn't think you had a choice of a rectifier that went to that high a voltage.
I will play around with it tomorrow. But thanks for the info Tom. Nick |
#8 |
You get a warning, but you also get a result. Simulated diodes don't smell quite as bad if you overvoltage them...
#9 |
Thats pretty funny.
Oh one other question. For you estimate you did, how did you get 3.3 % from 27:1? I did the same thing with the components I'm going to use and got 34.2 to 1. Would it be 2.9%? Thanks, Nick |
#10 | |
Excuse the mental arithmetic - 1/27 is 3.7%. Still more precision than it deserves, though, as it's a very rough approximation, ignoring loading. |
| RC filters | Sch3mat1c | Parts | 1 | 29th April 2011 08:34 PM |
| FM IF Filters | Juergen Knoop | Analogue Source | 4 | 30th October 2008 02:35 AM |
| PSU filters | kyrochan | Power Supplies | 1 | 2nd April 2005 04:05 PM |
| PI filters | Prune | Tubes / Valves | 3 | 26th September 2004 09:16 PM |
| Filters | Mr. Bungle | Solid State | 2 | 31st July 2004 05:08 PM |
| Page generated in 0.09162 seconds (86.12% PHP - 13.88% MySQL) with 10 queries |
