| diyAudio Sponsor | ||
I am building an audio mixer that uses 9 pairs of tubes and the heaters take 12V at a total of 5.4 amps dc. I don't fancy building a single 6amp 12V linear regulator so as I see it I have a couple of choices.
1. Build nine separate 1 amp or 5 separate 2 amp regulators - a bit cumbersome but workable. 2. Use an off the shelf 12V SMPSU. I have looked at a few examples. Most seem to switch at around 25KHz and at rated current have about 200mV pp ripple on the output (content unspecified but I bet there's some 25KHz in there). As a low cost, small size way of achieving what I want an SMPSU seems the way to go but this 25KHz power circuit worries me. OK, the PSU will be in a separate screened box some way from the mixer's sensitive circuits but still am am a little concerned. Anyone have any experience of using SMPSUs for heater supplies in low level audio or any other comments or ideas?? Cheers Ian
Ian |
#2 |
18 12AX7s at .15A each makes 2.7 amps, so I assume you are using a different tube.
Heater current doesn't vary much, once established at a voltage level, is it really necessary to have it regulated? If you are concerned with 200mv of ripple on your heaters, then slap an additional filter stage on the 12v coming out of that SMPS. Since one can make a darn quiet preamp with 6VAC on the heaters using good engineering practice, 200mv doesn't sound like much of a threat, after all 6VAC is nothing but ripple. |
#3 |
You could use a 32 ~36v transformer, rectified, and and run the tubes in three parallel strings of three each with a resistor (or RC filter) in series with each string. That would let you use a lower current transformer, and less dissipation in a regulator. What circuit are you building, and what tubes are you using?
#4 |
Audio Junkie
I have interest in using a SMPS for filaments too. I need to run 20 tubes at 6.3v at 2.5 amps each! that's 50 amps of 6.3v. if anyone has info on a supply if that nature, please let me know.
#5 |
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
I would look into parting out a full size automotive battery charger....perhaps one could run regulators for...lets say three per regulator. I would be leery of running it at full load however as most of these chargers have a low duty cycle. Besides the transformers of this size & rating tend to be very.."buzzy".
_________________________________________________R ick..... |
| how to wire 6.3VDC heater on a heater with center tap (12.6V series, 6.3V parallel)? | jarthel | Tubes / Valves | 9 | 14th April 2012 05:36 PM |
| Floating heater supplies | duderduderini | Tubes / Valves | 8 | 27th August 2007 01:25 PM |
| Common mode filtering for heater supplies. | jnb | Tubes / Valves | 2 | 13th July 2007 04:16 AM |
| Why separate AC heater supplies for driver and power tubes? | leadbelly | Tubes / Valves | 3 | 5th March 2006 12:34 PM |
| Common Mode Chokes for Heater Supplies | ppereira | Tubes / Valves | 7 | 29th January 2006 01:45 PM |
| Page generated in 0.07592 seconds (77.75% PHP - 22.25% MySQL) with 10 queries |
