diyAudio Sponsor
Old 11th July 2009, 05:26 PM   #1
ruffrecords's Avatar
Default Shipping Tube Gear
I recently sent a prototype tube mic pre from here in the UK to a client in the USA via DHL. The mic pre is built in a sealed die cast box and has a separate similarly constructed linear power supply. I surrounded each with about 2 inches of foam, then some polystyrene so they fitted snugly into a cardboard box.
Despite that, on arrival a tube had been shook out of its socket - OK maybe tubes should go separately - but worse, a sub-chassis that fitted into slots inside the die cast box had worked loose and pulled off some connections to its tube sockets.
Now given how I packed it, there was no way I expected a sub-chassis to work loose.; DHL must have really thrown it about to achieve that.
So my question is, what are others people's experiences of shipping tube based gear, especially internationally, and what lessons are there to be learned.
Cheers
Ian
Ian
Old 11th July 2009, 05:33 PM   #2
leadbelly's Avatar
IMHO, sounds like the problem is your mechanical design, and not shipping. As you already pointed out, the tubes should be packed separately. Also, relying on formed slots to hold a subchassis that contains heavy tube-amp-type parts simply won't do. You need to use good strong standoffs and screws. From your description, your preamp wouldn't even have survived as checked baggage.
Aerodynamics are for people who can't build engines. Enzo Ferrari
Old 11th July 2009, 06:02 PM   #3
Osprey is offline Osprey  United States
Ship the tubes in a separate box and double box the gear. Two inches of foam is not enough. That box should have been in a bigger box surrounded by "peanuts".
What to do with TMC tube radio gear? diamondsouled Tubes / Valves 4 31st March 2009 01:30 PM
Where to go for tube gear in Hong Kong? leadbelly Tubes / Valves 7 23rd February 2009 01:31 AM
tube walkie talkies just pay shipping berndt Swap Meet 1 19th October 2008 12:56 AM
Workshops for tube audio gear FranStar Introductions 2 29th January 2005 05:06 AM
Air travel with DIY tube gear. Bas Horneman Tubes / Valves 19 6th January 2004 09:04 AM
Page generated in 0.06919 seconds (74.31% PHP - 25.69% MySQL) with 10 queries
