diyAudio Sponsor
Old 11th July 2009, 04:11 PM   #1
Default Amplifier squeel at zero volume
Hello, I have designed amd built a guitar amp from scratch and am testing the power amp section of it at the moment. The phase splitter works great and I have inserted 2 of the 4 power valves (since they are two pairs in parallel) to avoid unecessarily damaging good valves.
The output it wired into a THD hotplate attenuater which has a load setting which allows the amp to operate without a speaker, and it then has 4 or 5 levels of attenuation. All works fine until no attenuation is used or very little is used.
When very little attenuation is used, a very loud squeel is heard from the speakers when the volume control is set to zero but at no other time. When no attenuation is used, the squeel is worse and present at all volume levels.
I'm somewhat baffled by this and was wondering if anybody had any ideas. The speaker cab is about 20 or so feet away in another room so feedback is not being induced by having the amp to close to it.
Thanks for any help!
Old 11th July 2009, 04:59 PM   #2
Mooly's Avatar
Valve amp or not oscillation is caused when certain conditions are met. I would check first the grounding, in particular that the volume control and input ground cannot be influenced by any currents flowing in the output stage, speaker or otherwise.
Is it a squeal ? Not motorboating or anything.
Old 11th July 2009, 05:22 PM   #3
analog_sa's Avatar
Lack of grid stoppers? Difficult to say without a circuit.
Old 11th July 2009, 05:44 PM   #4
The volume control is situated about 1cm from the main star ground point which is also right next to the output filter caps and I have used 1k5 grid stoppers on all 4 EL34's. I've attempted to attach the circuit diagram but struggled to get it small enough so quality is awful. As far as I'm aware the erroneous sound is a squeal as in high pitched. motorboating is more of a chugging sound if i'm not mistaken?
Old 11th July 2009, 06:03 PM   #5
analog_sa's Avatar
Installing grid stoppers on the phase splitter won't take much effort.
Volume control on DVD player remote. Lose resolution at low volume? Circlotron Digital Source 2 10th June 2011 07:20 PM
NAD 3020 amplifier volume problems Neilb Solid State 7 20th December 2006 11:44 PM
Right channel volume softens when amplifier is warm starbucks_sg Solid State 1 22nd March 2006 08:51 PM
Volume control for tube amplifier ?? hannes86 Tubes / Valves 13 21st December 2004 03:11 AM
Where to put volume potentiometer for headphone amplifier? psarin Headphone Systems 2 24th February 2003 02:31 AM
Page generated in 0.08722 seconds (77.53% PHP - 22.47% MySQL) with 11 queries
