| diyAudio Sponsor | ||
hi folk,
i'm in the process of starting a diy electrostatic speaker build and have just picked up a pair of c core 230v to 1240v transformers. the specs are 6.3v @1.3a 24 - 0 - 24 @ 40ma 1240v @ 15ma i was going to use these initially in reverse as step up transformers on my amps output into order to provide the necessary voltage for the stators but though they may be put to better use providing the dc bias for the speakers. Now i'm completely new to tubes but have build a number of ss voltage multipliers and full wave rectifers for use with electrostatic headphones. What i'd like to know is what mercury rectifer would be suitable for use with this kind of voltage and would the 6.3v 1.3a be enough for the heater? I've done some homework and I'm aware of the fact the mercury tubes normally need to be pre heated prior to turn on so i would include either dual switches allowing for pre heat or some type of timer for a delayed start. The reason why i'd like to do this is purely costmetic I could easily just use a lower voltage transformer with a solid state bridge followed by a suitable cockcroft walton voltage multiplier but i like the idea of incorporating big blue tubes into the base of the speakers. Thanks for you help on this i hope you can help out a tube noob. btw i has a look at the possibility of using these with tt21's or 75tl's (see told you i did some reading |
#2 |
btw forgot to mention that these will be used after a primary step up transfomers so output from the transfomers will be in the region of 3000v prior to being rectified - insulation is rated to 5000v
thanks |
#3 |
tarmac ripper
Mercury vapor rectifiers do need many ampers to heat the filament and they usually have 2.5 or 5V filament not 6.3V
75TLs are really rare and finding an output transformer for these puppies is even harder. Mine are biased at 900V and 40/50mA . Next project I have on the bench is a preamp/headphone amp with 75TLs and/or 75THs ... it happens those are my preferred tubes. Ciao Gianluca |
#4 |
thanks for the info gluca,
so i would need a separate 2.5 or 5v high amperage source. i suppose i could use a smps 5v supply the heater element will run on dc right ? any ideas of specific tubes i could look into. |
#5 | |
tarmac ripper
NOOOOOWAY! Filament is floating at high voltage. There are many MV rectifiers out there. Gianluca |
#6 |
ok so what would you suggest?
#7 |
Just get a simple filament transformer for them. Just make sure the secondary insulation is rated higher then the plate voltage,,,,,, OR ELSE,,,,,,,,BOOM.
All you need is ac too, don't know if anyone already told you that. Nick |
#8 |
has anybody checked to see just what the UV radiation of these tubes are?
moray james |
#9 |
I seriously doubt it's enough to worry about.
Nick |
| Mercury vapor rectifier tube question | nhuwar | Tubes / Valves | 13 | 7th November 2009 10:31 AM |
| Hickok 600A, shattered mercury rectifier... | jon_010101 | Tubes / Valves | 2 | 7th November 2008 09:39 AM |
| Bias range and selenium rectifier | mrshow4u | Tubes / Valves | 20 | 15th September 2006 08:15 PM |
| 966 mercury vapor rectifier | Dave Cigna | Tubes / Valves | 2 | 10th February 2006 09:41 PM |
| mercury vapor rectifier tubes on e-bay | karma | Tubes / Valves | 10 | 19th June 2005 02:52 PM |
| Page generated in 0.10372 seconds (80.64% PHP - 19.36% MySQL) with 10 queries |
