DHT bias and filament supply in one?
Old 9th July 2009, 02:09 AM   #1
dsavitsk is offline dsavitsk  United States
dsavitsk's Avatar
Default DHT bias and filament supply in one?
I was looking for a way to supply current to some 01-A's and bias them without adding any caps or batteries, and this occurred to me. It runs the filament current (250mA) through the bias resistor in addition to the plate current (~3mA) which keeps the resistor small (18R for a 4.5V bias instead of 1K5) meaning that it won't have much impact on rp ... But, I've never seen this done before which makes me think there might be issues. Any thoughts (other than the fact that the battery is upside down)?
Old 9th July 2009, 02:42 AM   #2
diy4 is offline diy4
Default Filament bias
Yes, it's been done before. It works quite well. Another variation on
this technique is to energize the filament separately, as usual, and
supply extra current to the smaller-than usual cathode resistor in order
to achieve the proper bias voltage. This provides an extra degree of
freedom.
Getting rid of the bypass cap without the usual penalty is quite a bonus.
Old 9th July 2009, 05:09 AM   #3
mach1 is offline mach1  Australia
Banned
If you search the Audioasylum you will find quite a few posts on this method of dht biasing.
Old 9th July 2009, 09:08 AM   #4
316a is offline 316a  England
316a's Avatar
Default Re: DHT bias and filament supply in one?
The main issue with filament bias is getting the filament supply quiet enough as any ripple will be amplified by the grid . This is more of an issue with higher mu , high filament current valves such as 3C24 . 01A will probably not need a cathode resistor if using as a linestage , there should be enough filament voltage to provide bias on it's own .
316A
Old 9th July 2009, 11:21 AM   #5
jeff mai is offline jeff mai  Australia
jeff mai's Avatar
See this:
http://www.vinylsavor.de/line01a.gif
Apparently it works very well.
Old 9th July 2009, 10:02 PM   #6
dsavitsk's Avatar
Originally posted by jeff mai
[Click the image to open in full size.
Really? I think I like my way better.
This is going to burn off on the order of 40W of heat and require a monster of a power supply in order to do away with a tiny filament supply.
Old 9th July 2009, 10:58 PM   #7
Default Thomas Mayer's supply
I first saw that schematic a few years ago. My impression was that Thomas was trying to do something more than just lower the cathode resistor. Wasteful? Indeed. But I suspect there is something to his idea. This is one I've always wanted to breadboard just to find out how it sounds.
Old 10th July 2009, 04:50 AM   #8
jeff mai's Avatar
I get what you're saying. I was just trying to point out that what you are doing has been tried with success. I've also seen it done with heater tubes like the 6SN7.
DHT bias and filament supply in one?Hide this!Advertise here!
K-502 Filament supply (or K-12M) jmillerdoc Tubes / Valves 6 18th November 2009 12:59 AM
DHT's, fixed bias, sharred filament supply audiowize Tubes / Valves 2 22nd October 2008 08:32 AM
Parallel vs. series filament supply - or another filament idea engels Tubes / Valves 11 13th May 2007 01:06 PM
How do I bias up a constant current series filament circuit? sgerus Tubes / Valves 19 24th October 2006 11:13 PM
When using a DC filament supply on a DHT... Saurav Tubes / Valves 31 18th September 2003 05:03 AM
Copyright ©1999-2017 diyAudio
