diyAudio Sponsor
Old 23rd January 2011, 11:24 AM   #41
andrew_whitham's Avatar
Originally Posted by cowboy99 View Post
Andy,
Very nice,
'Solids' are best thing that's happened to the CAM end of things. Bet your thinking about some piece/chassis .sldprt models that need some CNC 'tool path' via Mastercam V5 or say Catia...... ??
Chassis punches are for squares.
Charles
It works pretty well, yes. especially if you have a brother that does this sort of machining for a job. Chassis punches are comparitively hard work ;-) If I'm honest me butcheing sheetmetal with the tooling I have available at home is not ever going to get the same result...
Old 23rd January 2011, 12:41 PM   #42
Loren42 is offline Loren42  United States
Impressive work!
I just use models of the form factor to make sure things fit. I don't need the photorealistic look, but it does look amazing.
Old 21st September 2011, 10:47 AM   #43
tubegod is offline tubegod  United States
Are these models still available for download ?
Old 9th November 2011, 07:58 PM   #44
Default Valve models for SolidWorks
I have emailed Andrew a couple of days ago, but haven't had a reply yet. I'm also interested in valve models for S/W.
Adrian
Modelling PSU?! Psychobiker Tubes / Valves 24 13th March 2008 03:11 PM
modelling PSU for Aikido cbutterworth Tubes / Valves 16 1st December 2007 03:21 PM
Modelling of mosfets TroelsM Parts 11 26th July 2006 05:01 AM
Yet another online modelling app Vikash Multi-Way 5 29th August 2003 09:07 PM
Page generated in 0.08537 seconds (71.54% PHP - 28.46% MySQL) with 11 queries
