| diyAudio Sponsor | ||
Any idea? No spec sheet appears to include this parameter. A DC coupled SE amp is in the final stages of layout and I want to plan if a slow start is required. The driver plate load is a current source at 4 ma, the max momentary grid current will be somewhat less than that. Spice suggests a this will be a very short condition on start up, so far nothing untoward happened on the bench in regular use.
Ears aren't microphones. |
| KT88s and grid current | SpreadSpectrum | Tubes / Valves | 3 | 21st March 2008 07:33 PM |
| 6AS7G with grid current? | Wavebourn | Tubes / Valves | 1 | 16th November 2006 11:22 PM |
| KT66 SE amp, grid current or not? | jhaible | Tubes / Valves | 18 | 25th October 2006 10:56 AM |
| Current rating and tube current draw | cbutterworth | Tubes / Valves | 1 | 13th October 2006 04:42 AM |
| Transformer VA Rating vs. Current Rating | JhonDoe | Chip Amps | 45 | 5th June 2004 01:11 AM |
| Page generated in 0.04801 seconds (77.70% PHP - 22.30% MySQL) with 10 queries |
