Futterman style 6AS7 OTL with other tubes
Old 17th July 2009, 04:52 PM   #31
whitelabrat is offline whitelabrat  United States
whitelabrat's Avatar
It's a Solen PPB. ASC makes very large ones too. I've got a couple 600uF's sitting in a box somewhere. I could probably get away with driving speakers with those although their dropoff would be at 33Hz at 8 ohms.
Old 17th July 2009, 05:04 PM   #32
tubetvr is offline tubetvr
For example I was thinking of the 6CG7 where they would be only good for a couple milliwatts of output, but let's say I had 10 tubes in parallel for one channel. That's 20 triodes in action which would bring down the output resistance, and add up to a couple of watts to the output. I didn't say it was practical, just possible.
Yes, it is possible and can be made practical if you take care of distributing the current between all tubes, this can be done by matching all tubes and by using cathode resistors for each individual tube to avoid "current hogging" i.e. where one tube takes to high current, thereby failing and thereby making other tubes take to high current and so on...
Even when individual cathode resistors are used the current for parallel connected tubes should be reduced, figures for de-rating where given for regulator tubes in data sheets, (6AS7, 6C33C) typically the current for each tube was only half when 4 or more where used in parallel.
It is my understanding that the reliability problems of most commercial OTL amplifiers are due to a combination of running tubes way above ratings or no or too low de-rating of tubes when parallel connected.
Old 17th July 2009, 06:36 PM   #33
Brit01 is offline Brit01  United Kingdom
Solens are a little on the pricey side. 330uF film 99 USD. That will be one expensive headphone amp.
Couldn't find much for ASC caps (found their home page). How much do they run for?
Old 17th July 2009, 06:41 PM   #34
leadbelly is online now leadbelly  Canada
leadbelly's Avatar
Find one that is at a good price point, highest C / $, and parallel a bunch of them.
The whole problem with the world is that fools and fanatics are always so certain of themselves, and wiser people so full of doubts. Bertrand Russell
Old 17th July 2009, 07:10 PM   #35
Someone is selling them at $7.50 a pop on ebay. Buy two, get one free. Crazy good deal. It's the ASC GLY513. Just seach ebay for "ASC 600"
Old 17th July 2009, 11:30 PM   #36
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
What exactly is it you want to buid?
Do you want this amp to drive speakers or headphones?
TIA,
Frank
Old 18th July 2009, 12:08 AM   #37
We did get sidetracked a little.
Initial thread was for speakers but then I asked about the 100uF film output cap as I have built a headphone amp with electrolytics.
Sorry to confuse you.
Old 22nd July 2009, 12:36 PM   #38
desperateaudio is offline desperateaudio  United States
[i] PICS of the monsters are on the forum ... [/B]
Coresta
Can you tell me where on the forum pictures of your monsters can be found? I would love to see them? Any schematic available? Thx in advance
Old 22nd July 2009, 04:16 PM   #39
coresta is offline coresta  France
coresta's Avatar
somewhere in the "pictures gallery " file , or here , from Wagtbtoobz, my other french id : http://retro-forum.com/viewtopic.php?t=13883 in french ... many pictures and schematic published Cheers
Pierre
Old 22nd July 2009, 05:04 PM   #40
tyu is offline tyu  United States
Default eze OTL too diy an its a Circ lotron,
All parts an tubes an xfourms for two monos less than $500,
this has been up on the OTL site the King of OTL put it up not me
Futterman style 6AS7 OTL with other tubesHide this!Advertise here!
Futterman H-3 desperateaudio Tubes / Valves 41 29th December 2016 06:37 PM
Technics variation of Futterman SEPP. Circlotron Tubes / Valves 38 12th December 2008 03:54 PM
Octal tubes for 7695-style matrix amp? bst Tubes / Valves 3 15th November 2006 08:52 AM
Futterman OTL ferrite bead specification jwan Tubes / Valves 4 15th March 2004 07:17 PM
Improving the Futterman Sch3mat1c Tubes / Valves 6 18th August 2003 10:35 PM
Copyright ©1999-2017 diyAudio
