Friends
I have interest in use the type 31 in output... Anyone have experience with the 31 in output ? My last experience is with the 3c24 and it sound very fine, a sweet tube. This unknow tubes can sound very fine. Aldovan
#2 |
31 is a great sounding tube - sweet and very musical. One of my favourites. Great driver or line stage. Can be microphonic but there you go.
But as an output? Headphones maybe? andy |
#3 |
Andy
Yes, as output. I can use a pair in paralell and obtain 800mW. I want use in my PC computer output. Will work fine, with the adequate power for the small boxes and with high sound quality. Aldovan |
#4 |
How is the filament to work with in the 31?
#5 |
Ran across this thread and it got me thinking that just maybe I had a pair of 31's hidden away in my tube stash and sure enough I found a pair. I think they are only capable of about 3/8 of a watt surely not much. Anyone used them as a line stage? If so would you care to share your circuit and or observations and comments.
| tube output | chidpon | Digital Source | 1 | 12th October 2008 01:22 PM |
| SS or tube voltage amplifying stages in an amp with tube output? | ray_moth | Tubes / Valves | 14 | 4th July 2007 03:09 AM |
| Octal tube as headphone amp output tube | yagoolar | Headphone Systems | 6 | 25th November 2006 09:11 PM |
| Is it possible to get "tube sound" with just a tube preamp and chipamp output? | Spasticteapot | Instruments and Amps | 43 | 15th May 2006 05:28 PM |
| Output Tube biasing for Toroidal Output Transformer | gingertube | Tubes / Valves | 7 | 17th April 2005 04:40 PM |
