diyAudio Sponsor
Old 3rd May 2003, 02:26 PM   #1
Question Negative Feedback
When changing a negative feedback connection from 16 ohms to 8 ohms, how does one calculate the change in feedback resistor value?
Old 3rd May 2003, 03:27 PM   #2
SY's Avatar
0.707 times the 16 ohm value.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 4th May 2003, 11:43 PM   #3
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
If it has a capacitor across it, then you need to scale that by 1.414 (sqrt of 16/8) to maintain the correct time constant.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 5th May 2003, 12:03 AM   #4
diyAudio Senior Member
fdegrove's Avatar
Usually I just leave it as is....
Frank
Old 5th May 2003, 12:21 AM   #5
EC8010's Avatar
Default The radio boys will hate me for this, but...
If you scrap an old MW/LW valve radio for its (large) variable air-spaced capacitor, you are likely to have a 2 x 365pF or 2 x 500pF capacitor that is ideal for quickly determining optimum feedback capacitor value.
Old 5th May 2003, 12:23 AM   #6
fdegrove's Avatar
Default THE VARICAP?
Yup...good lateral thinking.
Frank
Old 5th May 2003, 12:38 AM   #7
EC8010's Avatar
Default Empericism rules
Rotary, rotary...
Bung a square wave up it, and two seconds find the answer. I was quite surprised. You can put a variable resistor in series with the capacitor, if you like, and waggle both.
Negative Feedback? Binaural Tubes / Valves 15 12th March 2009 07:05 PM
Negative Feedback AmpBuilder225 Tubes / Valves 7 20th February 2009 08:05 PM
Less Negative Feedback Is Better? CarlosT Chip Amps 25 14th December 2006 10:18 PM
Negative feedback? Solid Snake Solid State 33 14th March 2003 01:29 PM
Page generated in 0.06674 seconds (85.09% PHP - 14.91% MySQL) with 10 queries
