12AX7 heater filament resistance - Page 3 - diyAudio
Old 1st July 2009, 11:51 PM   #21
Send a message via MSN to bacon665
Theyre only half wave and since theyre rectifying in phase they should cancel. At least thats what i suspect he was doing.
Im too poor to pay 500 bux for a matched pair of 300B's to build something like that lol
its one of those things where it seems peter millet got bored and wnated to blow some serious money.
http://www.pmillett.com/uc300b.htm
ive looked over the schematic several times. He has another rectifier or two so im guessing its either for looks or hes generating multiple B+ feeds for the different tubes.
Old 2nd July 2009, 01:50 AM   #22
nigelwright7557's Avatar
Default Re: 12AX7 heater filament resistance
Originally posted by Ipanema
I bought a new reissue tungsol 12AX7. The heater filament pin 4 and 5 measured 40ohms but a RSD 12AT7 only measured 12ohms. When I connect it to 12V DC, it doesn't produce the magic glow. I would like to know whether this tube is malfunction because I got it from ebay. Thanks.
All my 12ax7's can be seen to glow easily.
I must admit different makes can be a bit different.
I have one that glows really bright then dims down after a couple of seconds.
I have others that just gradually glow brighter from switch on.
I now tend to use 12volt DC regulators for my heater circuits to try and get rid of hum.
Murton-Pike Systems PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk http://www.pcbcad51.co.uk
Old 2nd July 2009, 04:39 AM   #23
anatech is online now anatech  Canada
anatech's Avatar
Hi Nigel,
I've had better luck with AC heater power simply biased up +30 ~ +50 VDC.
The problem with an IC regulator is that they are usually not so good at higher frequencies, allowing some supply hash to get through. Are you using an L-C filter before your regulators to get rid of the higher frequency stuff.
-Chris
"Just because you can, doesn't mean you should" © my Wife
Old 2nd July 2009, 10:34 AM   #24
Originally posted by anatech
Hi Nigel,
-Chris
I am not using L-C just a large capacitor to filter out the rubbish.
Old 2nd July 2009, 06:21 PM   #25
Ipanema is offline Ipanema  Malaysia
Ipanema's Avatar
What's your favourite heater supply?
1) AC voltage source
2) DC voltage source
3) DC current source
and why it is better than the other IYO?
Old 2nd July 2009, 07:12 PM   #26
Thats a matter of opinion.
I prefer DC just because its easier to filter but i dont demand its use unless its a directly heated tube.
I find many old dvd players and such have SMPS with 5.6v and 12v regulated supplies. some with -30v and others. These work just fine for heater circuits. you still need a B+ feed unless you have a low voltage tube or you put the negative 30 to the cathode and 12 to the plate (this rarely meets tube operation specs but you might be lucky)
Very Basic 12AX7 Heater Question cfitzger Tubes / Valves 6 1st May 2014 04:05 PM
Is 6V DC too low for heater filament? Sunsun22 Tubes / Valves 8 29th December 2008 08:45 AM
5687 filament heater question dr._sleep Tubes / Valves 2 25th August 2005 04:45 AM
Troubl-shooting heater voltage for filament andy2 Tubes / Valves 12 10th January 2005 05:41 PM
grounding heater/filament center metebalci Tubes / Valves 6 27th March 2004 09:24 AM
Copyright ©1999-2017 diyAudio
