diyAudio Sponsor
Old 29th June 2009, 05:47 PM   #1
zobsky is offline zobsky  India
zobsky's Avatar
Default VR shunt regulator or RC filter
Requirements:
1. Input voltage: ~ 300 V DC, with a bit of ripple (lest say 5 mv, worst case)
2. Required output voltage: ~ 150 V DC , and about 30 mA current used to supply a D3A triode tube via a SE: PP interstage .
I currently use an RC stage to filter drop the voltage.
Would replacing this arrangement with a VR150 tube based shunt regulator yield additional benefits/drawbacks etc .. ?
"Any fool can know. The point is to understand" - Albert Einstein
Old 29th June 2009, 06:22 PM   #2
dsavitsk's Avatar
30mA is a bit high for a D3a ...
Upside -- Feed the shunt with a CCS and you get great ripple rejection and control the signal current loop largely keeping it out of the PS caps. Plus, VR tubes glow real pretty like.
Downside -- the VR tube may pop loudly when it strikes. Also, it has a pretty high impedance and can't be bypassed by anything larger than 100nF. You might do better with a zener + mosfet shunt of some sort.
http://www.ecp.cc/SSS.html
http://www.ecpaudio.com
Old 29th June 2009, 06:38 PM   #3
zobsky's Avatar
True,. D3A current draw is probably closer to 15 mA in practice. I spec'd 30mA as a worst case scenario in case I ever decide to change drivers.
As of now, the amp sounds pretty close to perfect (PP 2A3),. .just can't help wondering "what if i changed this or that"
HV Shunt Regulator PCB Algar_emi Group Buys 238 23rd May 2012 08:57 PM
How about shunt regulatorH uhcmos Solid State 4 2nd March 2007 09:32 AM
Shunt regulator tubee Tubes / Valves 12 2nd March 2006 01:08 PM
Page generated in 0.06725 seconds (71.73% PHP - 28.27% MySQL) with 10 queries
