diyAudio Sponsor
Old 29th June 2009, 05:06 PM   #1
jlsem is offline jlsem  United States
jlsem's Avatar
Default Screen Mode Mesh Plate?
This amp is described as using the screen as the anode in triode. However the screen of the PL519 is called a "mesh". Does anyone know if the screen of a PL519 is constructed as a mesh or is it a conventional grid?
http://www.oswaldsmillaudio.com/Products/amps.html
John
Old 29th June 2009, 06:28 PM   #2
HollowState's Avatar
I believe that OMA is using the term "mesh" very loosely to convey the idea of an open element as opposed to solid. I know of no tube, even in the transmitting/industrial world, that has a true mesh screen in keeping with proper definition. A mesh plate yes, and a mesh filament yes. But not a screen. Someine correct me if I'm wrong.
I also think this is a waste of a good tube. A design philosophy to be different for the sake of originality and marketing hype. The same results could be obtained with a much cheaper tube. But perhaps not as "cool" looking.
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University
Old 29th June 2009, 07:25 PM   #3
jlsem's Avatar
I believe that most if not all planar tubes have mesh elements (screens and control grids), but, yes, I wasn't aware of any concentrically constructed tubes that have mesh screens or control grids, other than the 849 and 851.
Judging from their other projects, I don't think OMA would ever release anything that didn't work particularly well. Using the word mesh maybe a low grade of marketing hype, but I don't think the device itself was marketing-hype borne.
John
Old 30th June 2009, 01:47 PM   #4
Merlinb is offline Merlinb  United Kingdom
Looks like a convenient way of using a cheap/unpopular valve and avoiding the use of the top-cap, for a safer design.
Old 1st July 2009, 12:55 AM   #5
tomchr is online now tomchr  United States
tomchr's Avatar
Well... The PL519 is a pentode, thus, would have two grids - a suppressor grid and a screen grid. It's not clear which one of the grids OMA uses as the anode in their "newly born triode". As far as I know either grid is usually quite small in area - especially the suppressor as it's only job is to catch secondary electrons knocked off the anode due to impact ionization. Using any of the grids as an anode strikes me as risky business, though. I can't imagine that they can handle much power dissipation...
I still think they should have gone with some nice turned walnut for the anode caps instead of those tire valve stem caps... :-p
~ Tom
Old 1st July 2009, 04:46 AM   #6
jlsem's Avatar
I doubt the suppressor grid is used because it can only handle 30V while the screen can safely dissipate 7W.
John
mesh plate el34 (supereTNT) dubdub Tubes / Valves 6 9th June 2008 05:18 AM
Emission Labs 300B Mesh plate 56oval Tubes / Valves 3 27th September 2007 12:07 PM
Experiences with TJ Mesh Plate DHT's kevinkr Tubes / Valves 16 3rd March 2006 04:34 AM
Tianjin 300B mesh plate Mohan Varkey Tubes / Valves 1 30th March 2003 07:08 PM
300B mesh plate, 2,5 Volt Heater reinhard Tubes / Valves 6 2nd September 2002 01:54 PM
Page generated in 0.08246 seconds (82.11% PHP - 17.89% MySQL) with 10 queries
