diyAudio Sponsor
Old 28th June 2009, 04:10 PM   #1
Default Testing an EL84 as a 6V6
I have a B&K 500 tube tester which I think is a very useful tester, however it won't test 9CV tubes like the EL84. A major shortcoming I think.
I wired up an adaptor with a 6V6 base and a 9 pin socket wired to the 9CV configuration, pluged in an EL84 and found that I am getting no cathode current to speak of. (BTW- 6V6s test just fine with proper cathode current).
I have 190 vdc plate voltage, 154 vdc screen voltage and a grounded cathode. Bias is -9 vdc. Heater voltage is 6.3. These values are measured off the 9 pin socket and I'm counting pin numbers correctly. I have tried several known good tubes.
I would expect high current with such low bias yet practicaly nothing (0.4ma). Any ideas?
Old 28th June 2009, 04:28 PM   #2
Cobra2 is offline Cobra2  Norway
DIY !
Cobra2's Avatar
Send a message via Skype™ to Cobra2
Default EL84
You can...with the 610 adapter...
Arne K
Ars longa, vita brevis
Old 28th June 2009, 04:51 PM   #3
Arne,
Thanks for your comments. I've not seen one but If I'm not mistaken the 610 panel was intended for the B&K 650. Mine is the 500. I looked at the wiring instructions at the Tone Lounge and couldn't gleen much about the construction from them as they only show the 8 pin socket.
Anyway, I don't have a 610 and I am looking for the DIY solution. The poor mans 610 panel I suppose.
Dave
Old 28th June 2009, 05:06 PM   #4
DIY !
Cobra2's Avatar
Maybe this helps?
Arne K
Old 28th June 2009, 10:49 PM   #5
Ty_Bower's Avatar
I can't find any datasheets to confirm my theory, but I suspect with 154 volts on the screen, the tube is cut off when you apply the -9 volt bias. Try a little less bias, maybe -7 volts or so. Otherwise, try raising the plate and screen voltage.
Edit: here's some datasheets:
http://frank.pocnet.net/sheetsE2.html
Look at the triode curves. Plate and screen tied together, 190 volts on both, the -9 volt grid line puts you pretty close to no conduction.
Old 29th June 2009, 01:16 AM   #6
Ty,
You are exactly right. -9 was too much bias.
The model 500 has a voltage divider that provides -18.1, -8.1 and -2.9 volt bias taps. I split the divider fruther, by using two resistors equal to the sum of the original, to get a 6.1 volt tap which seems to be about perfect for the plate voltage. It seems to work very well now.
I did not fully appreciate how much the bias needs to drop as the plate voltage is reduced. Thanks for the help.
Dave
Old 18th July 2011, 02:37 PM   #7
Dave,
Did you ever come up with sensitivity settings for the EL84s? I have a 500 and would love to be able to reliably test these tubes. Any diy info you could post would be much appreciated. Ex: which resistor did you split for your 6v tap? I have a complete manual with schematic and a calibration setup as well for reference.
Thanks,
Tony
Old 18th July 2011, 03:45 PM   #8
DF96 is offline DF96  England
For a pentode it is screen grid voltage which matters, not anode voltage.
5W EL84 drive EL84 SE Audio_idiot Tubes / Valves 31 Yesterday 08:38 PM
My New EL84 PP Sherman Tubes / Valves 17 10th April 2008 05:18 AM
Pse El84 vizion Tubes / Valves 3 16th October 2007 04:36 PM
Yet Another EL84 Amp sorenj07 Tubes / Valves 25 15th March 2007 04:04 AM
el84 - 807 ? then_dude Tubes / Valves 19 8th December 2005 09:32 PM
Page generated in 0.09347 seconds (80.52% PHP - 19.48% MySQL) with 11 queries
