| diyAudio Sponsor | ||
Is it me or is the tubelab SE's driver stage not capable of driving the 300B to clipping? Quick look yields ~85V pk-pk voltage swing, 300B needing about 140. Or is the powerdrive a gain stage after all? Thanks! Simon |
#2 |
Mine can push them into clipping...at least as far as I can tell (blue glow flickering off in the 300B).
#3 | |
For a B+ of 300V, that should give about a 200V PP max. Since both are over the 140V, it should not be an issue. Doug
Scienta sine ars nihil est - Science without Art is nothing. (Implies the converse as well) Mater tua criceta fuit, et pater tuo redoluit bacarum sambucus |
#4 | |
Cheers, Simon |
#6 | |
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
| Too much gain - help with changing driver tube. | colinB | Tubes / Valves | 15 | 21st November 2008 09:09 PM |
| Heretical Unity Gain line stage PLUS a little gain ? | yagas | Tubes / Valves | 7 | 24th January 2006 01:30 PM |
| Differing gain from driver and tube in a straight TL a problem? | GuyPanico | Subwoofers | 3 | 19th April 2005 08:44 AM |
| How to calculate the gain of an input-driver stage? | Antonio Tucci | Tubes / Valves | 0 | 8th October 2004 12:25 PM |
| Multiple driver sensitivity gain? | woody | Multi-Way | 3 | 12th February 2004 03:24 PM |
| Page generated in 0.08555 seconds (78.13% PHP - 21.87% MySQL) with 10 queries |
