diyAudio Sponsor
Old 25th June 2009, 12:42 AM   #1
mhconley's Avatar
Default First Project: 300B SET Monoblocks
Here I am pondering my first electronics project… I know I want to build a stereo amplifier and have investigated T-amps, Gainclones, and tube amps. (I know those first two are probably dirty words in this neck of the diyAudio forums.) Anyway, I have settled upon the idea of building a pair of 300B SET monoblocks. I have read the entire tube safety thread and am aware of the lethal voltages employed and will take the proper precautions. I hold a Comp Sci / EE double major but have spent my career on software although I do dabble in building PCs from components.
I am seeking some of the more experienced builders’ advice on a schematic. I have found various takes on the JE Labs 300B amplifier and it seems to be a simple design that I have read many good things about. Then I searched the diyAudio forums and found several threads that start out with folks stating they want to build this amp that quickly deteriorate into “that schematics no good”, “those parts are lousy”, “change this”, “change that” types of discussions that seem never ending.
Is the JE Labs schematic a good place to start? If not, is there a simple 300B SET amplifier / power supply plan / schematic / kit you would recommend? Are there updates to the JE Labs 300B? Any help, hints, sage advice and schematics would be greatly appreciated.
Thanks,
Martin
Old 25th June 2009, 01:04 AM   #2
dsavitsk's Avatar
Default Re: First Project: 300B SET Monoblocks
This one?
Not really.
There are a lot of things that can be done better. A good place to start that addresses many of these things is http://tubelab.com/TubelabSE.htm
http://www.ecpaudio.com
Old 25th June 2009, 01:16 AM   #3
mhconley's Avatar
That's the schematic...
I've been looking at the 300B DX:
and this variant:
Great start...
Martin
Old 25th June 2009, 02:02 AM   #4
athos56 is offline athos56  United States
athos56's Avatar
I think the JE labs ones are pretty standard except the 2 stages, I think there are schematics that only use one gain stage, like the WE 91a, or the Angela model 91.
I think there is some discussion about the operating points on the JE lab though, buy multiple cathode resistors to try different operating points.
Old 25th June 2009, 02:14 AM   #5
With all respect, I think this is an unwise decision. You are going spend LOTS of money on a 300B project. IMO, the unfortunate likelyhood of a very costly mistake suggests the thinking be revised.
What sort of speakers are available in your collection, now? Proper mating of speakers and amps goes a long way towards obtaining satisfactory results. SE 300Bs yield approx. 8 W. Speakers whose efficiency is upwards of 94 dB. and whose impedance curve is "flat" are needed.
Eli D.
Old 25th June 2009, 03:33 AM   #6
mhconley's Avatar
I understand the costs involved and the low power output. I am looking at building a high efficiency full-range single-driver TL speaker in conjunction with the amps. I have never seen a driver with a "flat" impedance curve, they all have peaks and valleys. Is there some maximum impedance I should stay under?
Martin
Old 25th June 2009, 04:10 AM   #7
rtsang is offline rtsang  Hong Kong
Don't discourage anyone buliding a 300B amp.
It seems that it is a ritual to DIY adulthood to build a 300B amp. (Just joking).
As long as the guy understood the cost and the speaker requirement, I think the money is still worth spent.
Build it like a universal SET, esp. with filament and output transformers with multiple taps, than one can later change to a 2A3, 45, 50, PX4 or what ever SET he would like to try.
Quite a bit of fun to try out different output tubes.
He can always sell the tubes that he does not like in eBay to recover part of the cost.
Old 25th June 2009, 05:21 AM   #8
dsavitsk's Avatar
Only ones I know if
Old 25th June 2009, 06:20 AM   #9
sorenj07's Avatar
Originally posted by dsavitsk
Only ones I know if
Wow How much do these headphones go for?
Old 25th June 2009, 06:59 AM   #10
dsavitsk's Avatar
http://www.headphone.com/guide/by-ma...rado-rs-1i.php
UcD400HG MonoBlocks project... help please croger Class D 18 15th February 2008 10:55 AM
300B stereo SE amp and PP2A3 monoblocks BHD Tubes / Valves 27 25th September 2004 05:03 AM
Diy speakers for 300b monoblocks? TubeHound Multi-Way 2 6th February 2003 02:35 PM
Quicksilver Monoblocks Project Miles Solid State 4 2nd January 2003 01:53 PM
Page generated in 0.11551 seconds (81.81% PHP - 18.19% MySQL) with 11 queries
