diyAudio Sponsor
Old 24th June 2009, 07:31 AM   #1
morfic is offline morfic  United States
Default Blue glass inside tubes
What was/is the purpose of the blue glass section in tubes, it's around the section with the plates, not above or below.
I am curious what it's for, blue and orange may near cancel each other out which may be a good military application at night? (yeah full on guess) But since my tube is brighter below that section anyway, i am not sure what the blue glass on the older versions was for (mine does not have this feature, it's a CV4014/EF91 tube)
Thanks for any info on this, googling mostly just finds ebay listings of such types (Amperex/Mullard) or stuff about blue glow, nothing about blue glass (same as search here it seems)
Daniel
Old 24th June 2009, 08:50 AM   #2
Colt45 is offline Colt45  Serbia
Send a message via ICQ to Colt45
You mean the kind of graphite-ish coating inside?
Something like aquadag i guess. I believe it's supposed to have some shielding effect, iirc.
edit, here's a pic http://www.oddmix.com/tubes/px/6cb6a.jpg
Old 24th June 2009, 01:20 PM   #3
Typically is more bright like this one.
Old 24th June 2009, 03:44 PM   #4
ilimzn is offline ilimzn  Croatia
Seen this on a couple of other tubes. In fact, I have several types of EF91 including 'civilian' ones, and all phillips/mullard have the blue coating. not sure what it is but it may well be blue in the visible spectrum, while absorbent in the IR spectrum, to facilitate cooling. Or, it could be slightly conductive and a form of shielding. The CEI/Thomson EF91 I also have, don't have it, but they do have a metallic coating reminiscent of a getter, but slightly different in color. The metalic nature would suggest a shield...
Do Sweep tubes Glow Blue? wrenchone Tubes / Valves 26 20th July 2009 10:32 PM
Used JJ EL34 blue tubes (matched) for sale aquasamo Swap Meet 0 18th February 2007 06:54 PM
for trade: 3x6922 tubes for one Alps Blue Velvet pot reaction Swap Meet 0 8th July 2004 08:39 PM
blue light inside a meter porfi4ever Pass Labs 15 6th May 2004 03:36 AM
Blue Tubes the glow jleaman Tubes / Valves 34 6th August 2002 11:07 AM
Page generated in 0.16949 seconds (38.30% PHP - 61.70% MySQL) with 10 queries
