| diyAudio Sponsor | ||
Does anyone know of any tubes, whether they be output or driver tubes, that have nice , round plates like the 6V6 or 6SL7 ?
Thanks..........................Blake |
#2 |
Do voltage regulators (0D3, etc.) count?
#3 |
Sure !
I am mainly concerned with driver and output tubes though. 6CA7 , round or flat ? KT88 , round or flat ? EL34 ? EL84 ? 6l6 ? 6SN7 ? (I looked at an old one yesterday that looked triangulated !) 6GK5 ? Etc................................Blake |
#4 |
6V6 is oval, not round !
6F6 is round. Almost all BPT are flat. Some triodes can be built both ways, it's a manufacturer decision. Why do you ask that ? Yves. |
#5 |
6AQ5s all seem to have nice big cylindrical plates. They all seem as well to tend to microphonicity. Ring like a bell when you tap on them.
Hm, Poinz |
#6 |
I have round plate examples of 50C5, 6AQ5, and 6BQ5.
#7 |
6AV6, if I remember correctly, a 12AX7-like triode with a round (cylindrical) plate with two small diodes along for the ride.
#8 |
KT88 is most definately flat.
NOS GE 12v6GT (beam pentode like kt88) have a bent plate and cathode sorta like ( and ) but a little straighter i might even go as far just to call it a tappared edge |
#9 |
Eimac tubes have cylindrical anodes and they glow
#10 |
Thanks for all the responses.
"Almost all BPT are flat." What is BPT ? Seems as though 6V6 ( Which I erroneously called 'round' , I meant 'round-ed') and 6SL7 both have the reputation of being very smooth sounding , and the 6V6 is supposed to be a very linear device (IDK about the 6SL7). I was curious to see if there happened to be any correllation between a tubes sonics and it's architecture. In my simple mind, it would seem that a smoothly curved/rounded plate would make for a better design , no edges or corners to offer deviations to the signal. Probably sounds stupid, but now you know why I asked. Are any of the popular tubes I listed above rounded/curved ? 6CA7 , rounded or flat ? EL34 ? EL84 ? 6l6 ? 6SN7 ? 6GK5 ? Thanks again...........................Blake |
| FS: NEO3 PDR w/ mounting plates | tf1216 | Swap Meet | 1 | 14th June 2007 01:17 PM |
| curved port tubes | jethari | Multi-Way | 3 | 22nd March 2006 11:59 PM |
| JE Labs 300b round 2 1/2 Copper Plates | TubeHound | Tubes / Valves | 18 | 9th April 2003 12:30 AM |
| mica plates | Kilowatt | Parts | 1 | 19th November 2001 06:08 AM |
| Page generated in 0.12468 seconds (66.07% PHP - 33.93% MySQL) with 11 queries |
