diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   Amp refurbishing question..... (http://www.diyaudio.com/forums/tubes-valves/146322-amp-refurbishing-question.html)
69CamaroSS396 22nd June 2009 12:52 PM
Are there any advantages to using 40% screen taps with push-pull 6BQ5s versus staying with an original design that didn't use them?
I'm replacing OPTs in an old amp I'm refurbishing and the Edcors I'm using have this connection. If it has audible advantages, I want to use it, of course.
If this is advantageous, are any other changes needed, such as a resistor between the screen and OPT?
Thanks, Greg
tim614 22nd June 2009 01:24 PM
you mean ultralinear conection?
and yes ultra linear is better less distortion
tim614 22nd June 2009 01:26 PM
where in ohio?
im in dublin ohio
what amp are you working on?
69CamaroSS396 22nd June 2009 01:41 PM
I'm in Chillicothe.
Off and on for months, I've been restoring a 1959 Silvertone Model 29 integrated.
Yes, it is the UL connection. My Edcors say screen on the tap, so I just called it that. I'm wondering if the lower distortion is actually anything audible, and since the amp is only 10-15 watts to begin with, we're looking at very little power output, which isn't always a bad thing, I know. Maybe I'll install a switch and I can go back and forth.
tim614 22nd June 2009 03:44 PM
Originally posted by 69CamaroSS396
I'm in Chillicothe.
switch is a good idea
15watts is plenty for efficient speaker
what speaker do you use?
boywonder 22nd June 2009 04:06 PM
Assuming that the original design has them wired as pentodes, won't changing to UL require other circuit mods as well?
ChrisA 22nd June 2009 04:09 PM
Re: Amp refurbishing question.....
Thanks, Greg
"UL" is a form of feedback. You get a more linear amp but at the cost of some output power.
If all else is equal a UL amp will fall between an triode and pentode in terms of output power and gain. Many people think it's a perfect trade off.
tim614 22nd June 2009 08:46 PM
2 Attachment(s)
, won't changing to UL require other circuit mods as well? [/B][/QUOTE]
no
compare these schem
pentode
tim614 22nd June 2009 08:54 PM
2 Attachment(s)
Ultralinear
69CamaroSS396 23rd June 2009 01:39 AM
The speakers I currently use are not particularly "tube friendly". 86dB sensitivity, but they sound fantastic. Signet bookshelf from about 1994. Bought them new at Progressive Audio on High Street in Cols. Actually got rave reviews as a budget buy. However, no low end to speak of.
I have parts and plans to build an open baffle based on suggestions I got from Martin King. Just don't have the time at the present to work on all the projects I'd like to. Unfortunately work gets in the way.
Resources saved on this page: MySQL 18.75%
