| diyAudio Sponsor | ||
Anyone could explain me what that mean? I can mount this tube horizontally but "with pin 1 and 8 in vertical plane"
Pins 1 and 8 are heater |
#2 |
That means that the manufacturer refuses to accept claims about damaged tube if it was not mounted according to their specifications.
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#3 |
It means with direct heated cathodes, over time the heater will sag if it's mounted horizontal otherwise and cause grief.
Even some indirect heated power tubes specify vertical mounting (H-sweeps). Cheers! |
#4 | |
I have used the principal the opposite way to save tubes that were discarded due to arc on start-up by rotating them so that the filament sags in the direction opposite to its distorted shape - curing the arcing problem. You can't do this with commercial gear or circuits you are building for use by anybody other than yourself but when it's a rare tube on the garage/shop clip-leaded breadboard amp it's just fine. |
#5 |
Mounting direct heating vertical, in conclusion, is a better idea.
Thanks to all |
#6 |
sometime the wires outside the tube will become soft when hot
so if the wires run level in the same plan as the tube they can short therefore you need to bring the wires to the socket so they will not short when they are hot and soft |
#7 | |
www.kta-hifi.net |
#8 |
yes but that is what the datasheet means......................!
#9 | |
No it's not... The data sheet talks about the internal alignment of the filament and other structures. (INTERNAL grid and filament sag are the actual concern.) You need to reread it a bit more carefully.
www.kta-hifi.net |
#10 |
Spaghetti
| 25-position switched attenuator using a pair of 5-position switches? | ray_moth | Tubes / Valves | 1 | 4th May 2008 08:02 AM |
| tube anti-vibration mounting | zigzagflux | Tubes / Valves | 19 | 9th September 2007 12:37 AM |
| Tube Socket Mounting - rigid or floating | skip_scratch | Tubes / Valves | 2 | 8th April 2006 05:25 PM |
| what is the mounting depth and mounting diameter of this? | lemans23 | Multi-Way | 2 | 26th October 2005 10:52 PM |
| Page generated in 0.14886 seconds (68.18% PHP - 31.82% MySQL) with 11 queries |
