diyAudio Sponsor
Old 21st June 2009, 03:53 PM   #1
Default Help identifying resistor value
I need some help identifying the value of this resistor, the schematic says it's a 47K, so it should be in that ballpark...
http://img44.imageshack.us/img44/9330/resistor.jpg
Thank you.
Old 21st June 2009, 04:36 PM   #2
mjf is offline mjf  Austria
hello.
a 47k has yellow violet orange rings.
a 4,7k has yellow violet red rings........
perhaps you can do some tests with a multimeter...........
greetings...........
Old 21st June 2009, 04:38 PM   #3
HollowState's Avatar
The picture you supplied is very poor quality. However, I copied it and was able to enlarge it and adjust the brightness level. The colors do look like yellow (4), violet (7), orange (3)(zeros) and gold (5%). So, 47,000 ohms and looks like a film resistor of about 2 watts compared to the small one.
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University
Old 21st June 2009, 04:40 PM   #4
richwalters's Avatar
91K..... compare colours with pic ?
richy
Old 21st June 2009, 05:52 PM   #5
llwhtt is offline llwhtt  United States
What amp is it? Looks British to me, not Marshall, Hiwatt, Vox, or Laney. Maybe we can find a schematic and then we'll know what the resistor value is if you can't measure it.
Craig
Old 21st June 2009, 07:25 PM   #6
ChrisA is offline ChrisA  United States
Default Re: Help identifying resistor value
Originally posted by gottlieb
[B]I need some help identifying the value of this resistor
Sometimes even if you have the resistor in you hand you can't tell if a band is orange or red. In those cases simply use a meter a measure it.
You will have to un-solder one end or if you are lazy cut one lead. Not to bad to waste a resistor in order to measure it. They are less than five cents each.
In a photo, no one can be sure of the color and we certainly can measure it.
Help Identifying Cap..... dmongrain Parts 13 1st June 2009 03:20 AM
Which resistor type for emitter resistor? sajti Parts 25 8th April 2009 06:12 AM
Help identifying IC mtl777 Parts 4 17th May 2008 09:10 PM
Identifying help placebo Full Range 0 31st July 2005 07:27 PM
screen-plate resistor and grid leak resistor metebalci Tubes / Valves 4 26th February 2004 03:18 AM
Page generated in 0.12399 seconds (55.33% PHP - 44.67% MySQL) with 11 queries
