diyAudio Sponsor
Old 20th June 2009, 03:39 PM   #1
Default Potentiometer value for 6SL7 input
I have a ALPS 100k log input pot then a 6SL7 with a plate load from 100k to 330k (but usually 100k)
The sound quality really increases when i pass the first third of the pot course (more open, better bass) but then is quite loud even with 90dB full range (2A3 output).
Is the pot value too low for the 6SL7 ?
thanks in advance.
eric
Old 20th June 2009, 05:09 PM   #2
Eric,
Changing pots. will not help. Ratio, not absolute value, governs in a resistive voltage divider. Padding the pot. with 100 KOhms of fixed resistance will attenuate the I/P signal by 6 dB., when the control is set for max. volume.
Eli D.
Old 20th June 2009, 05:09 PM   #3
leadbelly's Avatar
Well no psychics have responded yet so I guess you're just going to have actually give us information.
What does the circuit look like? Do you have a schematic? Is the grid DC coupled? Is there a grid resistor? The pot is wired correctly? The source is OK with other amps?
EDIT: Ooops, beat me to it Eli.
Aerodynamics are for people who can't build engines. Enzo Ferrari
Old 21st June 2009, 04:14 PM   #4
Miles Prower's Avatar
Default Re: Potentiometer value for 6SL7 input
If anything, I'd say that a 100K pot is too high. Here's the spec sheet data for the 6SL7:
Cgk= 2.15pF
Crt= 3.5pF
Given the plate loads you give, you're looking at a voltage gain of ~40 -- ~50. If Av= 40, then:
Cmiller= 3.5(40 + 1)= 143.5pF
Ci= 143.5 + 2.15 + 10= 155.65pF (Adding an additional 10pF for Cstray -- this might be even higher, but you probably can't get it much lower)
Since:
w= 1 / RC
w= 1 / (100E3 X 155.65E-12)= 64.25E3 rad/sec= 10.23KHz
That costs you quite a bit of your highs. So the result you describe is quite understandable: you have better bass since you've made an accidental treble cut circuit in addition to a volume control.
That's the big problem with those high gain triodes: big Cmiller's. I usually avoid the problem by making volume controls from 100K linear pots with the slider paralleled to the ground end with a 16K resistor to make a log pot function that way. It not only gives a guard resistor in case the pot goes open, it also gets that resistance down so that you get the low pass pole out of the audio band. I've also found that log taper pots go scratchy pretty quick, whereas linear pots do not.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 23rd June 2009, 03:54 AM   #5
kevinkr's Avatar
Actually the maximum resistance of a 100K pot relative to the grid assuming a reasonably good voltage source driving it is at electrical mid point, the thevenin equivalent source resistance of said pot at mid point is then 25Kohms giving a -3dB at about 40kHz. (Still not that spectacular.)
Still I think Miles is right about the pot, however it may be a quality issue as well as a parametric one. Pots have lots of stray capacitance all on their own, and depending on how it is distributed you may get quite poor frequency response over 1/3rd to 1/2 of its rotation with the best measured performance happening over a range very close to maximum volume, and at the other volume extreme near maximum attenuation. This neglects other sources of stray capacitance like long wires, etc.
I would recommend a 50K pot or less if the driving source is solid state, if tube 50K/100K would be reasonable.
I prefer stepped attenuators to any pots I have heard or can afford.
www.kta-hifi.net
Old 24th June 2009, 10:31 PM   #6
Effectively, the best sound is achieved with the using the 100k ALPS pot at maximum volume.
Amplifier is fed directly from CD player.
I have also in stock a good quality 50k TKD KO-ON pot i was using with a trends TA 10.1.
I tried it a few months ago and was not convinced then, but it is worth a new try...the amplifier is not exactly the same.
Steeped pot with high quality resistors could certainly be a good choice, but as they are not cheap i need first to be sure of the value and the kind of resistors i like most (and since resistors matching and mixing is haute cuisine, it could be the most difficult point).
Old 27th June 2009, 11:57 PM   #7
Read this thread and try it out. Works pretty good.
Passive Preamp
.....................Blake
Keep it simple
My Page Of SV and DIY Stereo Links
Can I change the input to a 6SL7? Original Burnedfingers Tubes / Valves 9 14th December 2008 06:35 PM
6SL7 5E3 - together at last? atmars Tubes / Valves 12 24th November 2008 01:59 AM
Input potentiometer selection koolatron Tubes / Valves 12 18th April 2008 05:04 PM
Preamp schema: Input to buffer to potentiometer to gainstage or what? Groundloops Solid State 9 8th February 2008 11:29 AM
6sl7 omom123 Tubes / Valves 0 23rd August 2007 07:11 PM
Page generated in 0.20869 seconds (39.98% PHP - 60.02% MySQL) with 10 queries
