| diyAudio Sponsor | ||
I have been trying this software but the queiscent voltage seems ok except at B3+.
What I did was I measure the current drawn at each B section but at B3, the actual measurement is 109V instead of the simulated 30V. Can someone point out the error whether it is due to the transformer impedance or the capacitance ESR.
#2 |
Put in "after reporting a delay of 15 seconds" and re-run the sim. That last cap needs time to charge up. 180K through a 22uF cap. Long time constant.
#3 |
It works. Thks for your help.
However, the slow rising curve was not reflecting what actually happen. The actual case was there is a overshoot before settling to the final voltage. 1. Now the simulated voltage at B+ rail match the actual measured figures except the transformer secondary. I have to lower it down to 248V instead of the actual 266V. Is it caused by the wrong selection of Diodes voltage drop ? 2. For tube integrated amp (1x12AX7, 2x12AU7, 4x6V6GT), what is the acceptable range of ripple at B1+, B2+ and B3+? |
| Dumb question about Edge Baffle Designer | Aengus | Everything Else | 2 | 4th February 2009 08:07 PM |
| Quick question regarding PSU Designer II | w00t | Tubes / Valves | 5 | 28th October 2004 11:38 AM |
| DuncanAmps PSU Designer Question | trustalbini | Tubes / Valves | 4 | 11th June 2003 01:33 AM |
| Need some help with PSU Designer II | Bricolo | Parts | 12 | 14th November 2002 06:42 PM |
| Hello, from amp designer | rmetz | Introductions | 2 | 29th January 2002 07:18 PM |
| Page generated in 0.08339 seconds (56.11% PHP - 43.89% MySQL) with 10 queries |
