diyAudio Sponsor
Old 20th June 2009, 07:07 AM   #1
Rob11966's Avatar
Default Plate current Question
Here's something that confuses me.
I am talking about the 845 tube but I imagine that this question applies to other tubes as well.
With respect to the operating plate current, the ratings differ depending on the plate voltage. Looking at the 845 Amperex data for example the typical operating values are as follows (plate voltage plate current) -
750v 95mA
1000v 65mA
1250v 52mA
I understand why you have to adjust the bias voltage to limit/adjust the plate current but I don't understand why the recommended typical operating current goes down with increased plate voltage. If the plate is capable of handling 95mA at 750v, why can't it handle 95mA at 1250v? More specifically what the problem with running a tube at say 1000v and 95mA.
I am sure I have missed some basic point. Any advice appreciated.
Rob
Old 20th June 2009, 07:18 AM   #2
rtsang is offline rtsang  Hong Kong
Default Plate dissipation
Plate dissipation = plate voltage drop x plate current
The power dissipation is the fixed value.
For 300B, it is 40W.
For 2A3, 15W.
Of course too much voltage and too much current will also kill a tube, but usually we hit the power limit first.
Old 20th June 2009, 07:22 AM   #3
Power dissipation limit.
Old 20th June 2009, 08:13 AM   #4
Rob11966's Avatar
Obvious - now. Thanks guys.
Rob
Plate Current VS Plate Voltage Graphs Captn Dave Tubes / Valves 2 13th February 2009 08:57 PM
Plate Amp Standby Current (PE 500W/1000W) gmikol Subwoofers 6 20th February 2006 06:19 AM
Welborne 300b DRD plate current dsavitsk Tubes / Valves 0 9th September 2005 07:47 PM
El509 Plate current question audio_siuming Tubes / Valves 9 25th February 2004 11:01 PM
active plate load v.s. constant current... mwmitchell Tubes / Valves 3 8th August 2002 09:34 PM
Page generated in 0.07724 seconds (64.19% PHP - 35.81% MySQL) with 10 queries
