| diyAudio Sponsor | ||
Hi all,
I have the 5-0-5 taps off my preamp transformer available. I used one leg and the ground to illuminate a 5V blue LED as an on/off light. The other leg is floating. At first the LED was lit without visible intermission. Over the last couple of months the LED has started to blink on and off with decreasing frequency. Clearly this does not represent the 60 Hz pulse going to it. I suspect I am destroying the LED and possibly endangering the transformer by wiring it directly this way. (My thinking was that as long as there is no negative voltage going to the LED, the rapid + pulses would suffice. Now I'm thinking an RC might be necessary. Is this a bad wiring scheme? What would be a simple circuit I could employ that would use the available 5V tap for this purpose? What possible damage might I be doing to the tranny or the preamp circuit? Thanks, gary |
#2 |
Does your LED have a series resistor?
#3 |
Are you protecting the LED from reverse voltages ?
Resistor - LED -! - REVERSE DIODE -!
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
#4 |
I second the suspicion that the reverse voltage killed the LED. A small-signal diode (1N4148 comes to mind) in anti-parallel with the LED would do the trick. You'll probably need to replace the LED, though.
I assume the "5V LED" has a series resistor built in. ~Tom |
#6 |
Thanks for the responses,
I did not use a resistor because I get 5V from that tap and I ordered a somewhat uncommon 5V LED from digikey for that purpose. If I understand correctly by attaching it's + terminal to one of the 5V taps and it's - terminal to the ground I don't get any negative voltage, but rather a bumpy half wave 5V that oscillates between 5 and 0 volts. Please correct me if I have this wrong. I wonder if I shouldn't put a cap in front of it to smooth it out. Problem is then I will be losing voltage and underpowering the LED. Any other suggestions? gary |
#7 | |
Yes, use the available "10" VRMS, a series current limiting resistor, and a protective series PN junction diode, along with the indicator part. Your thinking about "5" VAC is erroneous. First and foremost, the max. voltage present is (sic) 1.4X the AC RMS value. Another consideration is that the voltage actually present varies with loading.
Eli D. |
#8 |
My Manley amp runs the input and phase inverter tubes on 12VDC however the power LED is run on AC right off of the heater winding with a 511 Ohm series resistor. If you are running 6 volt heaters try a 250 Ohm resistor in series with the LED.
Craig |
#9 |
Thank you gentlemen.
#10 | |
You need to feed them DC, and make certain you include a ballast resistor. Even then, no guarantees they won't eventually poof. |
| DVC Wiring Question | 69stingray | Multi-Way | 3 | 6th April 2007 12:42 PM |
| Amp/Sub Wiring Question | OKCMustangGT | Car Audio | 3 | 31st August 2006 09:14 AM |
| Wiring question | LizardBrain | Multi-Way | 4 | 26th March 2006 03:46 PM |
| newbie with input tran. question and wiring question | imo | Solid State | 0 | 18th January 2006 10:10 PM |
| Another wiring question. | Prof | Chip Amps | 1 | 3rd July 2003 07:39 AM |
| Page generated in 0.14733 seconds (63.52% PHP - 36.48% MySQL) with 11 queries |
