| diyAudio Sponsor | ||
I was working on someone's amp the other day. It is a 6J5 DC coupled to a 45. The owner wants, for now, to keep the tubes and the topology as is. But, we added a CCS load and LED bias to the first stage to try to improve it a little. However, I am concerned that if something goes wrong, that the second stage could be damaged. Can anyone comment on the wisdom of adding a couple of resistors to form a voltage divider (the orange resistors shown) to make sure that the output tube maintains bias in the event of the driver crapping out? This is done on the Aikido, but I am unsure of how the larger output tube changes things. I also assume that this will defeat some of the benefits of the CCS, though with high enough value resistors, the reduced load should be negligible. Thought?
http://www.ecpaudio.com |
#2 |
The resistors will defeat the purpose of the CCS.
You could always put a fuse in the B+ to the 45 tube.
Frank |
#3 |
Yeah, that's a good idea. Something like a 100mA slow blow perhaps?
#4 | |
You could always replace the cathode resistor of the output stage with a CCS . That would prevent any nastiness 316A |
#5 |
Funny I should find this thread, its my amp in question (Hey Doug
I would love to hear other comments regarding the use of fuses on the plate of the output tube to protect it from the bias running away. I don't think I hear any sonic degradation but the idea of the signal and all that voltage and current running through the fuse and contact holders could be of concern. I will add that regardless I am very highly appreciative of dsavistk's efforts and mindfulness of my safety |
#6 | |
Been there, blown that. (not with a 45 though)
If you were to install a fuse, I would put it in the cathode circuit. This way the grid current is killed if the fuse blows. I run my 45's in the 30 mA range. I find that many of them are emission limited in the 50 ma range although mine are all well used. This means that you need a fuse in the 50 mA range. That will be hard to find, but I have seen some 63's. Another possibility is to use a CCS in the cathode of the 45. It could be used to establish the bias. Use it instead of the cathode resistor and set it to the desired bias current. It could also be used as a safety feature. Put in series with the cathode resistor and set it for a few mA more than the desired bias current. It will stay saturated during normal operation, but limit the total tube current to a non fatal value if something goes wrong. You still need the cathode bypass cap either way.
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
#7 |
You may use my gyrator (SVCS), but take DC feedback from output tube's cathode instead of anode of the tube it loads. In such case you will have stable cathode voltage even without an input tube.
| Bias Supply resistors | AmpBuilder225 | Tubes / Valves | 14 | 19th April 2009 12:34 AM |
| A75 protection diodes and Cascode load resistors | slogan2112 | Pass Labs | 1 | 13th October 2008 10:10 PM |
| Anti-reverse-bias protection diode vs. performance | hollowman | Power Supplies | 5 | 28th September 2008 11:15 PM |
| PTC resistors for protection of small transformers | roffe | Parts | 2 | 15th November 2007 01:03 PM |
| AA1800 bias resistors | eds65gto | Solid State | 2 | 20th January 2005 03:21 PM |
| Page generated in 0.12491 seconds (55.55% PHP - 44.45% MySQL) with 11 queries |
