diyAudio Sponsor
Old 18th June 2009, 10:16 PM   #1
Thumbs up Help! tube amp burnt?
Hi guys
I have an "old" Icon audio 40, it has been working fine but yesterday I heard a big pop coming from the right speaker. Today the same hapened again but that noise was stronger, then i switched off the amp but I could smell something burninng in side. I opened the amp and I could see what I think that is a resistor burnt.
I can simply replace that resistor but I have no idea what was the cause. I'd like to know to avoid other problems.
Here are some pics with a darker resistor (in the midle of the picture)
[IMG]
http://http://img190.imageshack.us/i...mpunder003.jpg[/IMG] Click the image to open in full size. Click the image to open in full size. Click the image to open in full size. Click the image to open in full size.
Thanks in advance.
flatsound
Old 18th June 2009, 10:31 PM   #2
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Looks like the tube has a burnt loose wire on a screen grid that shorted on a suppressor that is connected to cathode. Put a new tube and replace the resistor (it's so called screen grid stopper). Don't forget to rebias the output stage.
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Old 18th June 2009, 10:36 PM   #3
Ty_Bower's Avatar
It looks like it's a resistor in series with the screen grid (pin 4) and using the non-connected pin 6 as a tie point. There may be an ultra-linear screen tap from the output transformer (orange lead?) landed on pin 6? It's difficult to tell - the photo is somewhat fuzzy. Use the macro setting (little flower icon) on your camera if it has one, and do not use any telephoto (don't zoom in).
Old 19th June 2009, 03:05 PM   #4
Thanks for your opinions guys
By the way, can you recommend an easy book about that subject? A nice and easy book always can be usefull in the future for a neewbe like me.
Thanks a lot
regards
flatsound
Old 24th June 2009, 10:50 PM   #5
Finally some good pics. Ty_Bower, thanks for your sugestion about the pics
http://img200.imageshack.us/gal.php?g=mytubeamp2019.jpg
flatsound
Old 24th June 2009, 11:22 PM   #6
llwhtt is offline llwhtt  United States
Generally the only reason for a screen resistor to go up in smoke is a bad tube. As suggested earlier replace the resistor(100 Ohms?) and the tube. Then check bias and adjust if necessary.
Craig
Old 24th June 2009, 11:43 PM   #7
Send a message via MSN to bacon665
Might be worth it to change to a ceramic insulated wirewound resistor, they can take more abuse then the polyester (im assuming thats what burnt) and have less signal drift in MOSt applications.
There are always exceptions to this though.
Old 25th June 2009, 05:47 PM   #8
Thanks for your replies guys.
llwhtt, Yes the value resistor is 100 ohms, +/-5%. The color strips are Brown, Black, Brown and gold.
Do you sugest any website to buy it from? Preferably English ones.
Old 25th June 2009, 06:12 PM   #9
bigwill is offline bigwill  United Kingdom
Farnell, CPC (part of farnell), Radio Spares, eBay
Old 26th June 2009, 02:41 AM   #10
tube depot has nice resistors if you need carbon.metal oxide and high power.
http://www.tubedepot.com/resistors.html
i cant tell if the ones in your picture are half watt or quarter
it looks to be the metal oxide resistors here http://www.tubedepot.com/r-283.html
IRFP064 gets burnt xyz9915 Power Supplies 30 5th February 2009 02:57 AM
Need Help - Burnt Sanken p.heimpold Solid State 16 30th May 2007 05:05 PM
Sub burnt bad. Garbage? Miedosoracing Subwoofers 4 27th April 2006 01:59 PM
burnt transformer A'af Digital Source 1 20th May 2005 11:23 PM
Page generated in 0.15285 seconds (62.59% PHP - 37.41% MySQL) with 10 queries
